Hey guys, I'm in the process of tuning the fan in my computer and I was wondering if there is a better fan tuning software than AI suite? It's temperature readings are wildly inaccurate when the cpu heats up. Any suggestions? And I would prefer not to use speedfan...thanks so much!
https://linustechtips.com/topic/569330-fan-control-software/
2 minutes ago, DaltonM said:
MSI Afterburner? Are you fans plugged into your MOBO? If they're powered directly off the PSU through Molex or something else, you won't be able to control them without a hardware fan controller
Oh I didn't realize that you could use Afterburner to control the fans. How exactly do you do that???
https://linustechtips.com/topic/569330-fan-control-software/#findComment-7471978
Well, you can set it to automatic, I do know that.
1 minute ago, namarino said:
hahaha Is that my only option???
Not the only, however it is the best in my opinion. You can look up how to properly use it on YouTube.
GPU: XFX RX 7900 XTX
CPU: Ryzen 7 7800X3D
https://linustechtips.com/topic/569330-fan-control-software/#findComment-7472000
14 hours ago, DaltonM said:
.... I'm shamed about your reading skills. We are talking about case fan/cpu fan control. Not GPU fans. If Afterburner can control CPU/case fans, please correct my foolishness.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/569330-fan-control-software/#findComment-7475069
24 minutes ago, DaltonM said:
He never said CPU or GPU fan.
Well, OP suggest talk about CPU/Chassis fans because controlling with AI Suite or Speedfan. And you also are asking how fans are connected while suggesting Afterburner. Which to my knowledge doesn't support controlling CPU/Chassis fans. Yet.
https://linustechtips.com/topic/569330-fan-control-software/#findComment-7475365
