What is the difference between the Silverstone TD02-LITE AIO, and the Silverstone TD02-SLIM AIO Liquid coolers? I know there is a 3$ price difference right now on amazon, but im not sure what the difference is. Both are 120mm fans, and is 240mm so it holds two of them, but i dont know what the difference is.
http://www.amazon.com/dp/B011VCVX42/?tag=extension-kb-20
Thats the LITE version, and the SLIM version you have to click on is right next to it.
Aso, next to the TD02 versions, there is TD03 versions. Whats the difference in those as well?
https://linustechtips.com/topic/569304-question-on-two-products/
27 minutes ago, ZeusXI said:
So the  SLIM radiator is slightly thinner than the LITE? Does that do anything really?
slightly higher temps
its meant for tiny systems
https://linustechtips.com/topic/569304-question-on-two-products/#findComment-7471843
