So i am trying to write my own version of this mod for kerbal space program that allows me to add more planets. Any ways i need help identifying what programming language this is. Just to give you an example
@Kopernicus:AFTER[Kopernicus]
    Body
        name = Bastion
        Orbit
            referenceBody = Sun
            inclination = 0
            eccentricity = 0
            semiMajorAxis = 200500000000
            longitudeOfAscendingNode = 0
            argumentOfPeriapsis = 0
            meanAnomalyAtEpoch = 0
            epoch = 0
            color = 0.1,0.1,1,1
        Properties
            description = Bastion is the king of the gas giants
            radius = 8000000
            geeASL = 1.5
            rotationPeriod = 36000
            rotates = true
            tidallyLocked = false
            initialRotation = 0
            isHomeWorld = false
            timewarpAltitudeLimits = 0 30000 30000 60000 100000 300000 600000 800000
            ScienceValues
                landedDataValue = 8
                splashedDataValue = 1
                flyingLowDataValue = 5
                flyingHighDataValue = 5
                inSpaceLowDataValue = 7
                inSpaceHighDataValue = 5
                recoveryValue = 5
                flyingAltitudeThreshold = 12000
                spaceAltitudeThreshold = 140000
        ScaledVersion
            type = Atmospheric
            fadeStart = 0
            fadeEnd = 0
            Material
                // Common scaled space settings
                texture = KopernicusExamples/Creating New Bodies/GasGiant/PluginData/Color.dds
                shininess = 0
                specular = 0.0,0.0,0.0,1.0
                // Atmosphere settings
                rimPower = 2.06
                rimBlend = 0.3
                // Atmosphere color ramp texture
                Gradient
                    0.0 = 0.094,0.220,0.643,1
                    0.6 = 0.0549,0.0784,0.141,1
                    1.0 = 0.0196,0.0196,0.0596,1
        Atmosphere
            // effectively the ambient lighting color for all objects on the ground of this body (provides a slight tint)
            ambientColor = 0.006,0.187,0.8,1
            // shader.invWaveLength = Color( 1 / r^4, 1 / g^4, 1 / b^4, 0.5);
            lightColor = 0.709,0.788,0.543,0
            // General atmosphere settings
            enabled = true
            oxygen = false
            altitude = 200000.0
            // Atmosphere Pressure
            // pressure (in atm) = multipler * e ^ -(altitude / (scaleHeight * 1000))
            pressureCurve
                key = 0 1722.525 -3.68761403636364E-02 -3.68761403636364E-02
                key = 13750 1215.4779 -2.89618181818182E-02 -2.89618181818182E-02
                key = 27500 926.0747733 -1.70812909090909E-02 -1.70812909090909E-02
                key = 41250 745.7422867 -1.22066367272727E-02 -1.22066367272727E-02
                key = 55000 590.39232 -1.03885874909091E-02 -1.03885874909091E-02
                key = 68750 460.0561533 -8.63595672727273E-03 -8.63595672727273E-03
                key = 82500 352.9034533 -7.05044647272727E-03 -7.05044647272727E-03
                key = 96250 266.1688867 -5.6660456E-03 -5.6660456E-03
                key = 110000 197.0872333 -4.48274916363636E-03 -4.48274916363636E-03
                key = 123750 142.8932733 -3.50056581818182E-03 -3.50056581818182E-03
                key = 137500 100.8216733 -2.71949803636364E-03 -2.71949803636364E-03
                key = 151250 68.1071 -2.13953963636364E-03 -2.13953963636364E-03
                key = 165000 41.98433333 -1.65774109090909E-03 -1.65774109090909E-03
                key = 178750 22.51922 -1.00126501090909E-03 -1.00126501090909E-03
                key = 192500 14.44954667 -4.06759432727273E-04 -4.06759432727273E-04
                key = 206250 11.33333333 -2.27824727272727E-04 -2.27824727272727E-04
                key = 220000 8.184366667 -2.25669374545455E-04 -2.25669374545455E-04
                key = 233750 5.127426667 -2.06283192727273E-04 -2.06283192727273E-04
                key = 247500 2.51158 -1.61502101818182E-04 -1.61502101818182E-04
                key = 261250 0.68612 -9.13301818181818E-05 -9.13301818181818E-05
                key = 275000 0 -4.98996363636364E-05 -4.98996363636364E-05
            // temperature Curve
            temperatureCurve
                key = 0 141.67 -0.002333333455 -0.002333333455
                key = 33000 104.4583677 -0.0003304941091 -0.0003294753455
                key = 57750 104.4583677 0.0003294753455 0.0003294753455
                key = 85250 131.0381051 0.0001800779636 0.0001800779636
                key = 154000 131.0381051 -0.0002483375636 -0.0002483375636
                key = 220000 90.44359713 -0.0003304941091 -0.0003304941091
                key = 247500 90.44359713 0.0001722816364 0.0001722816364
                key = 275000 111.2241191 0.0002525833091 0.0002525833091
                key = 343750 0 -0.0001634942182 -0.0001634942182
if anyone can help me understand this it would be very helpful.
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/568905-need-help-identifying-a-programming-language/
Its not a language its just data structures written out in formatted text. Its basically just an object name then within the parenthesis the data members of said object.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
ahh makes sense. any idea how i can learn more about how to do this kind of thing?
Perhaps try starting with parsing a simple data format such as INI files or Wavefront OBJ (this one is specific to 3D models but is a nice easy format to learn how parse text files.) This is completely language agnostic so it does not matter which programming language you choose to use to parse a file.
Maybe Lua?
Lua is very used very often in games as either a scripting language or a way to store data.
This would describe a monster, for example :
monster = {
    health = 100,
    name "Troll",
    lootTypes = { "gold", "chain_armor" }
And of course then it comes to actually how you interact with the Lua code. Using a library called LuaTable , it will look something like this (in C++) :
Luatable::Value definition;
Monster monster;
definition.loadFromFile("Troll.lua");
troll.health = definition["monster"]["health"].asInt();
troll.name = definition["monster"]["name"].asString();
Luatable::Array& lootTypes = definition["monster"]["lootTypes"].asArray();
for (int i = 0; i < lootTypes.size(); ++i)
    monster.addLootType(lootTypes[i].asString());
Ah , it's not Lua. It has slight syntax variations. It looks very similar though. As other have said , it's just some data storage format probably.
