HELP HELP HELP
Solved by BurblingBarbacoa,
Hey. That's a decent platform for some upgrades. Here are my reccomended changes for the build:
- first thing is to replace that graphics card. Maybe look at an r7 370 or a gtx950. That card that you have is not going to be doing much.
- The cpu is not ideal but is abosolutley fine for some gaming and standard home use. All good there. Same for the motherboard
- maybe grab an extra 4gb of ram. 8gb is a minimum for gaming and general use
- That power supply. I'm not 100% but it looks pretty sketch. I would grab a good cheap supply. The other components are worth nothing if the power supply blows up and kills them. Look at the corsair CX500. After the GPU upgrade this.
- HDD is fine. Maybe look at a small SSD for the so and a few programs and games. Only if you really care about launch and boot times. The HDD is fine though.
- Case and cooling?
This should run those games fine at mid to high settings at 1080p 60htz.
Hope I helped ![]()
tell me what Yu think and good luck
