What is this use for? you can get windows 10 keys cheaper at G2A/Kinguin/Reddit
Magical Pineapples
https://linustechtips.com/topic/567766-thoughts-on-my-build/#findComment-7456787
Things wrong
  • H97, you go witha  4790k, you're gonna want an board that supports overclocking
  • Don't use SuperNOVA's go with an EVGA G2 750w
  • 840 is out of date go with the 850 Evo
  • You can get a windows 10 key on reddit for 25~ dollars
  • 390 > 970 in most situations
  • a i5 is all you need for gaming, save yourself $100 and put it into a better GPU.
  • 5400RPM is ungodly slow go with 7200RPM (Aka Seagate Barracuda or WD Black)
  • Edit: Now that I see you're gonna be doing Editing too
  • Faster RAM, buy them in a single 16GB kit for best operation
https://linustechtips.com/topic/567766-thoughts-on-my-build/#findComment-7456799
5 minutes ago, Perfx said:
Gaming and editing
o hey, its my build from an earlier thread
here
PCPartPicker part list: http://pcpartpicker.com/p/H84Pt6
Price breakdown by merchant: http://pcpartpicker.com/p/H84Pt6/by_merchant/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($239.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.89 @ OutletPC)
Motherboard: MSI H97 PC MATE ATX LGA1150 Motherboard  ($88.99 @ Amazon)
Memory: Kingston HyperX Fury White 8GB (2 x 4GB) DDR3-1600 Memory  ($37.38 @ Amazon)
Memory: Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1600 Memory  ($34.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($88.00 @ Amazon)
Storage: Western Digital Blue 2TB 3.5" 5400RPM Internal Hard Drive  ($74.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  ($363.98 @ Newegg)
Case: NZXT Noctis 450 ATX Mid Tower Case  ($119.99 @ Directron)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($87.95 @ OutletPC)
Total: $1221.14
Generated by PCPartPicker 2016-03-18 20:31 EDT-0400
comments:
1) changed your processor to a non-overclocking xeon, same performance as an i7 4790, but with the price of an i5
2) changed your ssd back to 850, 840 is out dated
3) you can get windows cheaper elsewhere
PS: i went with a 970 for him because he wanted a white and blue build
i cant find any 390 with that colour
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/567766-thoughts-on-my-build/#findComment-7456813
2 minutes ago, Ronnie76 said:
Things wrong
I'm going for a gaming and editing so I went for i7 and i don't plan on over clocking
https://linustechtips.com/topic/567766-thoughts-on-my-build/#findComment-7456816
Then you should get a locked CPU. Save yourself $20 and go with a cheaper motherboard because Z97 is too expensive if you don't plans overclocking, just get this instead.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($351.98 @ Newegg)
Motherboard: ASRock X99 Extreme3 ATX LGA2011-3 Motherboard  ($169.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($64.99 @ SuperBiiz)
Storage: Samsung 850 EVO 250GB M.2-2280 Solid State Drive  ($79.99 @ Amazon)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($64.99 @ Newegg)
Video Card: Sapphire Radeon R9 390X 8GB Tri-X OC Video Card  ($370.40 @ Newegg)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($84.99 @ NCIX US)
Total: $1322.21
Generated by PCPartPicker 2016-03-18 20:34 EDT-0400
edit: and as I mentioned in my previous post, go to Reddit and get yourself a $25~ dollar windows 10 key.
https://linustechtips.com/topic/567766-thoughts-on-my-build/#findComment-7456832
$1432
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($329.89 @ OutletPC)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Motherboard: MSI H110M Pro-VD Micro ATX LGA1151 Motherboard  ($54.99 @ Amazon)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($56.99 @ NCIX US)
Storage: Hitachi Deskstar 7K2000 2TB 3.5" 7200RPM Internal Hard Drive  ($55.95 @ Amazon)
Video Card: EVGA GeForce GTX 980 Ti 6GB Video Card  ($598.99 @ Newegg)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($46.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($48.99 @ NCIX US)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($89.99 @ NCIX US)
Total: $1382.27
Generated by PCPartPicker 2016-03-18 20:38 EDT-0400
https://linustechtips.com/topic/567766-thoughts-on-my-build/#findComment-7456848
1 hour ago, stconquest said:
$1432
Total: $1382.27
What about this? http://pcpartpicker.com/p/WDFCsY
https://linustechtips.com/topic/567766-thoughts-on-my-build/#findComment-7457280
here
  Reveal hidden contents
Total: $1221.14
comments:
https://linustechtips.com/topic/567766-thoughts-on-my-build/#findComment-7457285
2 minutes ago, Perfx said:
1) get a 390 for more performance, unless you need nvidia's features
2) you dont need 750W, 550W is plenty enough
this is from a performance stand point
from aesthetics:
1) get a white cooler or black cooler (not sure what colour you're going for now)
2) get a better looking SSD, and two of them for the noctis 450's front mounted 2x 2.5inch drive
3) grab some LEDs
https://linustechtips.com/topic/567766-thoughts-on-my-build/#findComment-7457308
from aesthetics:
3) grab some LEDs
390?
https://linustechtips.com/topic/567766-thoughts-on-my-build/#findComment-7457356
$80 cheaper:
Paying a lot more for that blue/white/grey mobo, but you get SLI.
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($142.98 @ Newegg)
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB) DDR4-3000 Memory  ($74.99 @ Newegg)
Storage: Hitachi Deskstar 7K2000 2TB 3.5" 7200RPM Internal Hard Drive  ($56.95 @ Amazon)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0+ Video Card  ($300.80 @ Newegg)
Monitor: Acer G257HL BMIDX 60Hz 25.0" Monitor  ($135.99 @ Newegg)
Total: $1392.06
Generated by PCPartPicker 2016-03-19 07:07 EDT-0400
https://linustechtips.com/topic/567766-thoughts-on-my-build/#findComment-7458489
26 minutes ago, Ronnie76 said:
Finally someone who appreciates my work <3
The Gigabyte X99 Gaming 5 mATX mobo is on sale for like $130... but it is black and red.
Darn, it was a rebate, $150:   http://www.newegg.com/Product/Product.aspx?Item=N82E16813128748&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
https://linustechtips.com/topic/567766-thoughts-on-my-build/#findComment-7458812
Rebates are a bitch sometimes, i wish PCPartPicker would add an option to do components w/o rebates.
https://linustechtips.com/topic/567766-thoughts-on-my-build/#findComment-7459764
