My dad just bought a 100$ computer for his business (Without even telling me which made me very mad since i would love to build a new one but whatever)
It's windows xp and the problem is, when he opens the computer.... he needs to put in a username and password and we dont know what they are.... can i somehow change the pass somehow? or do something to get to the desktop? Thanks!
PLEASE HELP
*I can't find my windows 8 disk... Wouldn't wanna buy a new one for a 100$ crappy work pc.
hi
https://linustechtips.com/topic/56748-please-help/
Just download a new ISO
http://www.w7forums.com/official-windows-7-sp1-iso-image-downloads-t12325.html
Make a USB Boot drive from it with http://www.microsoftstore.com/store/msusa/html/pbPage.Help_Win7_usbdvd_dwnTool
And re-install, and just keep re-arming the activation (30 days) in a command prompt (type slmgr /rearm) to re-arm the activation for 30 days
Or you can do w/e you choose to do
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/56748-please-help/#findComment-766914
And re-install, and just keep re-arming the activation (30 days) or w/e you choose to do
Don't have a USB... How much gb's do i need for windows for a usb? I will buy one i guess.
But any other faster way?
Thanks
hi
https://linustechtips.com/topic/56748-please-help/#findComment-766932
If the computer has the product key on it reinstalll windows using that key.
Build Log: Monochrome
CPU: Intel Core i5-4670K | Motherboard: Gigabyte GA-Z87MX-D3H | Graphics Card: Asus HD 7970 DirectCU II | RAM: Corsair Vengeance Pro 8GB | PSU: Corsair CXM 600 | Storage: OCZ Vertex 4 128GB,2 Seagate Baracuda 3TB | Case: Corsair 350D Window
https://linustechtips.com/topic/56748-please-help/#findComment-766937
Thanks
Windows XP then around 1/2GB
Any other version then at least 4GB
System Specs:
CPU: Ryzen 7 5800X
GPU: Radeon RX 7900 XT
RAM: 32GB 3600MHz
HDD: 1TB Sabrent NVMe -  WD 1TB Black - WD 2TB Green -  WD 4TB Blue
MB: Gigabyte  B550 Gaming X- RGB Disabled
PSU: Corsair RM850x 80 Plus Gold
Case: BeQuiet! Silent Base 801 Black
Cooler: Noctua NH-DH15
https://linustechtips.com/topic/56748-please-help/#findComment-766938
Thanks
You need a 4-8gb usb drive.
You can use the same program I linked to burn the ISO to a disc as-well...you will have a disk somewhere surely ;p lol
https://linustechtips.com/topic/56748-please-help/#findComment-766943
Can I somehow do it from the Bios?
You might be able to get into the password thing in safe mode....
Just remembered i have a usb that is about 2gb or maybe 8 dont remember... what windows is the best? windows 7 ultimate 64bit?
Get 32bit version of windows 7 ultimate from the ISO links.
https://linustechtips.com/topic/56748-please-help/#findComment-766953
I used a 4 GB USB key to install win7 IIRC.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/56748-please-help/#findComment-766961
But with 32bit i will be limited to 4gb of ram, am i right?
Why would a computer he bought for $100 with windows xp have more than 4gb of ram <.<
But yes lol
https://linustechtips.com/topic/56748-please-help/#findComment-766969
If you just need to get in,
Download OPHCRACK and burn it to a disc.
Make sure the boot order is optical drive before hard drive.
Run the software.
Write down the possible passwords.
Take the disc out, reboot.
Profit.
Blackwidow Ultimate 2013 - Naga 2012 - Naga - Tiamat 2.2 - Electra - Nostromo - Manticor - Scarab - Mouse Bungee - Hoodie - Messenger Bag - Keyboard Bag - L33T Pack - Synapse - Comms - Game Booster
https://linustechtips.com/topic/56748-please-help/#findComment-771964
Pretty much the fastest way to clear the password is by using Offline NT password and registry editor, if you follow the youtube link that Lanoi linked then that explains everything you need to do :P
http://pogostick.net/~pnh/ntpasswd/ then press bootdisk and then scroll down to find the download links
https://linustechtips.com/topic/56748-please-help/#findComment-772191
