What can I do for networking with 2 pcs?
VoyexTech
I have two older computers and I wonder what I can with them for networking. (Doesn't need to be very functional just cool)
I have an Anet A8 as my project printer and a i3 MK3 for when I want things to work.
I extrude my own filament and haven't saved a penny yet.
My PC:
CPU: Intel i7 8700k
Motherboard: MSI Z370-A Pro
RAM: G.Skill Ripjaws V (2x8GB) DDR4-3200
GPU: GTX 1070 Founders Edition (OC'd)
Storage: 2x 2TB Seagate 5400RPM, 128GB ADATA SSD
Power Supply: EVGA Supernova 750w  B2
Cooling: Noctua NH-D15. 3 Intake Fans, 2 Outtake
Case: Fractal Design Define R6
cluster computing? not sure you could make it work but its something and its cool :P
Builds:
Could be some kind of redundant file server system, if one fails, the other one stays up. That's technically also a cluster.
6 minutes ago, Toxicknight79 said:
Networking to pcs is kinda easy  what OS you running on them?
Wundoes XP and Vista. I could move to Linux though
My PC:
CPU: Intel i7 8700k
hmmm , windows xp I think is ok I skipped vista and went to 7 ,  I think though it might be difficult , but heres an article you could read that might and I stress MIGHT work.
here
That's fine, but remember, if you don't connect them to a router, you have to set a static IP on both pcs or they will not connect at all, you won't even be able to ping the other pc
Use the Rocks linux distro and start building a cluster. Then if you get any more older systems you can just add them to the cluster and expand. If you want some older systems for a project I actually have at least 4 complete systems available. They are older (early-mid 2000's era), but they work. I have been wanting to build a cluster with them for a while, I just don't have the space/time right now.
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
That is actually an awesome idea, I'm definitely going to try that someday!
