Does Linux have problems with high end gaming motherboards? Such as not being able to use their wifi-cards, logic processors, etc. I have an MSI Godlike Gaming motherboard and I have finally become so annoyed with Windows that I want to move to Linux and just play Windows games in a VM or through Wine but when I installed Ubuntu on a flash drive and booted from it...... Well all these things happened:
  • I couldn't get any internet signal even though I had it through Ethernet
  • i couldn't boot from any of my drives or install Ubuntu on to them due to "wrong kind of partition"
  • it didn't like my Corsair K95 very much
  • I couldn't access a lot of stuff and I just generally was annoyed.
Help? I'm a bit of a Linux noob so these could all just be me.
https://linustechtips.com/topic/566056-linux-problems-with-gaming-motherboards/
linus takes a lot of research and learning and finding 3rd party drivers that will work with your stuff
because most motherboard manufacturers dont provide linux drivers
There seems to be no Linux support for that motherboard on the msi web page. What I have found with linux is unless the mfg. supports it with drivers. Only hardware that will run on generic drivers seems to work.
I am a paid professional, but only when I am at work...and getting paid.
Sounds like you are missing a driver. Look up which WiFi chip your motherboard has and download that.
Probably because it is formatted as NTFS. It should automatically create a new one and format it though. I think you are missing some step when you are doing the installation.
Why not? It should work with the generic keyboard driver just fine.
Not sure if Corsair has any GNU/Linux drivers for the customization software, but from what I know it seems like that is saved in memory on the keyboard, so you might not even need the drivers for anything more than programming it in the first place.
Access what kind of stuff? You should be able to access anything if you are root, but you shouldn't have to for most tasks.
I had trouble with Ubuntu. At first everything was fine, then my sound stopped working entirely. Couldn't ever find out why.
Dubs are better than subs
Well when you're booted in a live environment, you don't have very many privileges, which may be why you "can't access a lot of stuff". Also, if that mobo has Killer NIC, I'm pretty sure you're screwed (afaik there's little/no support for Killer) unless that's the board that you can replace the NIC on. As for installing, you could try using Gparted to wipe the drive (but I'd refrain from that if you're not totally committed to switching.)
A Guide For Getting Started With Linux
My first rig:   CPU: AMD Athlon X4 860k Cooler: Cooler Master Hyper T4 MoBo: Gigabyte GA-F2A88XM-DH3 Video Card: EVGA GTX 750 Ti Superclocked RAM: 8GB Kingston HyperX Fury White 1866MHz Storage: WD Blue 1TB PSU: EVGA 100-W1-0500-KR Case: Rosewill SRM-01
My board uses a Killer NIC, I had no issues connecting to the internet. Ubuntu did everything on its own just fine.
Then again, that's Ubuntu.
Huh. Maybe it's mobile NICs that don't work/work well. Not really sure about that, just something I heard somewhere.
I've heard there are a LOT of problems with mobile NIC's on Linux. A lot of problems with Laptops in general.
Yeah I just looked at the Ubuntu Supported Hardware page, and it seems like Broadcom and Intel are basically the only two that are widely supported.
The "more common" the hardware you're using, the better the Linux support will be. There can be issues with niche or high-end motherboards like this with driver support because they are uncommon and fairly new (basically nobody has compiled the drivers for it yet because the low demand and user base of such products is so low).
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
