I am into music production and many times get stuck while producing.....
 I use ableton as my main DAW and it uses enormous cpu processing
Thinking about assembling system specifically for DAW.
Suggest CPU (both intel and AMD) focusing on Multi-Threading and Multi-core processing !
*(Have already considered upgrading RAM)
*(Will not consider upgrading to an SSD)
Currently using a mobile Intel i5-5200U @2.20GHz (Low to mediocre loads only; Pathetic)
P.S. : DAWs and the VSTs used in it are like CPU Hogs
https://linustechtips.com/topic/565670-cpu-for-daw/
https://linustechtips.com/topic/565670-cpu-for-daw/#findComment-7434056
For a cpu, I would suggest an i7 4790k/4790 or 6700k/6700 since rendering would be faster and loading cpu intensive vsts will also be more quick and also since most DAWs utilize multi-core cpus. More info: http://support.image-line.com/knowledgebase/base.php?id=55&ans=214 (Based off of my knowledge on FL Studio).
https://linustechtips.com/topic/565670-cpu-for-daw/#findComment-7434067
6 minutes ago, TekRa said:
What would be more efiicient : Intel or Amd .......... like i can get more cores at the same cost of an intel
I don't really know, I have limited knowledge on AMD CPUs compared to Intel cpus. I (personally) would pick an intel cpu due to its hyper threading but thats just my opinion so take it with a grain of salt. The best advice I can give you is to look up the recommended hardware requirements for your DAW.
https://linustechtips.com/topic/565670-cpu-for-daw/#findComment-7434155
INTEL , but it depends on your budget, used xeons like the e5 2670 go for like $70 US on ebay and are 8c/16t but a mobo can cost around $200, but if you have a bigger budget you can get two of them and run them off of a dual socket mobo.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/565670-cpu-for-daw/#findComment-7434336
