Hey guys, I need a $500 pc build for my parents. They do regular web surfing and work on their computers and they where talking about using dual monitors.. So my plan is as follows: Samsung 850 Evo 500gb SSD for main storage because I know they will probably not use more than that and they want the computer to be very responsive. For the CPU im torn between getting a Quad core or Dual core, I want something thats decently fast and future proof Preferably not spending over $150 on the cpu and just going with the stock cpu fan. As for graphics I believe I will go with integrated graphics, but the issue is can that handle 2 monitors? Or will I need a cheap GPU? For RAM im going to get 1600MHZ 8GB. For the PSU im not sure what to get here, because I dont want a cheap psu that will blow, And something 400-500W would work. For the case We want it to be a small case, No bigger than Mid Tower Micro-ATX form. And I will settle for whatever for the motherboard as long as its micro-atx. If someone could give me suggestions and maybe a PC part picker list that would be great! Thanks!
[CPU: 4.3 GHZ I5-4670K] [MB: Gigabyte Z87-D3H] [RAM: Corsair Vengeance 1833 MHZ (8GB)]
[GPU: Gigabyte G1 Gaming GTX 1070] [PSU: Corsair CX-750] [Cooler: Hyper 212 Evo]
[Storage: 2TB 7200RPM HDD / 500GB Samsung 850 EVO ] [Case: ThermalTake Chaser-MK 1]
[Keyboard:Corsair K70 RGB Cherry MX] [Mouse: Razer DeathAdder] [Monitor: 2 x ASUS 24 INCH IPS (1440p Soon)]
https://linustechtips.com/topic/564790-pc-build-for-parents/
Get a Pentium G3258...decent for the price
And get a cheap GPU while youre at it, if you ever want to run 2  monitors
Please vote for Donald Trump. I am out of sitcoms to watch.
When lyfe gives you HDDs, make SSDs
https://linustechtips.com/topic/564790-pc-build-for-parents/#findComment-7424884
http://pcpartpicker.com/p/RbnTdC Here are the basics
I think you can get a cheap case for 20 bucks
https://linustechtips.com/topic/564790-pc-build-for-parents/#findComment-7424898
get 250 gb ssd storage, it's plenty for your parents :)
and yes iGPU can handle 2 monitors, i built this for my parents:
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($189.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.04 @ Newegg)
Motherboard: Asus H110I-PLUS/CSM Mini ITX LGA1151 Motherboard  ($82.00 @ Amazon)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  ($35.88 @ OutletPC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($87.49 @ Amazon)
Storage: Western Digital Blue 2TB 3.5" 5400RPM Internal Hard Drive  ($74.88 @ OutletPC)
Case: RAIJINTEK Metis (Blue) Mini ITX Tower Case  ($57.99 @ Newegg)
Power Supply: Silverstone 450W 80+ Bronze Certified SFX Power Supply  ($59.99 @ NCIX US)
Monitor: Dell SE2216H 60Hz 21.5" Monitor  ($99.99 @ Newegg)
Total: $816.24
Generated by PCPartPicker 2016-03-13 13:11 EDT-0400
This system is 500$ without the monitors, but 700$ with the monitors
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($119.99 @ SuperBiiz)
Storage: Western Digital Blue 1TB 3.5" 5400RPM Internal Hard Drive  ($55.89 @ OutletPC)
Total: $699.21
Generated by PCPartPicker 2016-03-13 13:13 EDT-0400
https://linustechtips.com/topic/564790-pc-build-for-parents/#findComment-7424902
Motherboard: ASRock H110M-ITX Mini ITX LGA1151 Motherboard  ($66.99 @ SuperBiiz)
Case: Silverstone SG05BB-LITE Mini ITX Desktop Case  ($38.99 @ SuperBiiz)
Power Supply: Silverstone Strider Gold 450W 80+ Gold Certified Fully-Modular SFX Power Supply  ($88.99 @ SuperBiiz)
Total: $438.33
Generated by PCPartPicker 2016-03-13 13:14 EDT-0400
It's small, like you asked and it supports two monitors via the igpu.
I5 4470     -     Cooler Master Hyper 212 evo    -    Asus Strix GTX960    -    12Gb ram    -    Adata SP600 128Gb    -    Seagate 2Tb    -    AsRock Fatal1ty B85 Killer    -    Seasonic M12II EVO 520
IN WIN 703    -     Dell P2414H    -    LG Flatron M197WDP    -    CMSTORM Quickfire XT with MX blue's    -    Logitech  G502
Quote
"To finish first, you first have to finish"
https://linustechtips.com/topic/564790-pc-build-for-parents/#findComment-7424918
Not sure if you needed monitors in the build or not,
If you don't, then for the price this is a decent build http://pcpartpicker.com/p/hnmPt6 with a lifespan to boot. The slightly slower athlon x4 860k is going to make it a much better tradeoff than the dual core pentium, which will start to bottleneck should they begin any sort of multitasking.
If you DO need monitors, then some sacrifices have to be made, and even then the total comes out just barely over 500 http://pcpartpicker.com/p/gzK8WZ
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/564790-pc-build-for-parents/#findComment-7424943
Just now, Nacho Marco Segui said:
The pentium is not good for gaming anymore, the 860k has way better value
Not looking for cpu thats good for gaming, Looking for something thats for everyday usage and future proof
https://linustechtips.com/topic/564790-pc-build-for-parents/#findComment-7424945
Then the pentium is your CPU
https://linustechtips.com/topic/564790-pc-build-for-parents/#findComment-7424977
A Skylake i3 provides sufficient power. In the build I suggest the motherboard is a touch more expensive as it has WiFi and supports two HDMI up to 4096, and a DVI-D up to 1920 simultaneously. A single stick of memory, to allow for an upgrade and a decent 480GB ssd.
While many steer clear of all cases that include psu, I do not. There are a few manufacturers that tend to include decent psu in some of their cases. Inwin is one such.
Motherboard: Gigabyte GA-H170N-WIFI Mini ITX LGA1151 Motherboard  ($113.99 @ SuperBiiz)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2400 Memory  ($29.99 @ Newegg)
Storage: Mushkin Chronos 480GB 2.5" Solid State Drive  ($119.99 @ Newegg)
Case: Inwin BP655.FH300TB3 Mini ITX Tower Case w/200W Power Supply  ($57.99 @ SuperBiiz)
Total: $441.95
Generated by PCPartPicker 2016-03-13 14:26 EDT-0400
https://linustechtips.com/topic/564790-pc-build-for-parents/#findComment-7425259
Total: $441.95
I really like that build, Might switch out the RAM for 2 sticks and really like the Wi-Fi motherboard and Processer, Dont like that PSU tho
https://linustechtips.com/topic/564790-pc-build-for-parents/#findComment-7425551
