Posted March 13, 2016 Hi, how are you doing? Today I've been looking for a good fan to replace my PSU's noisy one. Yep, I will loose the warranty but unfortunately don't have more PSUs lying around, no money for a new one and no time to have my PC disabled for 3 weeks.. So I watched some easy guides, seems pretty easy but then read some comments that the PSU delivers very little voltage to the fan and the only I have and it good quality spins up only when it gets 6 volts. Is it true? Also, I don't want to sacrifice my noctuas because the PSU is just not worth it. The requirements for the fan are just to work, be quiet, have at least some static pressure and, not very important but look cool if I want to sell it or something.. Thank You! I need S340. But more Define S'ish Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 13, 2016 Arctic F12 or Scythe grand flex, cheap fans that are good. If you want better looks, get a corsair fan Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 13, 2016 just be careful. some parts of a PSU can kill you if you touch them. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 13, 2016 Author 8 minutes ago, Nacho Marco Segui said: Arctic F12 or Scythe grand flex, cheap fans that are good. If you want better looks, get a corsair fan Thank you. Is the Arctic one silent or not? I will put even my S12A in here if I could but have only one case fan so it kinda sucks. It looks great. And corsair? Never again, had a fan and a PSU with a fan from them. Neither is quiet. 8 minutes ago, Beeeyeee said: just be careful. some parts of a PSU can kill you if you touch them. Yeah blah blah blah, I've never seen a person killed by a PSU.. And also, I don't really mind loosing my life much, it would just be a gentle zap, strain, shock, death... Also, I'm careful right? And capacitors should discharge within couple of seconds, if not, max a day. I need S340. But more Define S'ish Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 13, 2016 ziptie the fan on the fan slot and use molex power/3pin Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
