USB showing less Gb
Go to solution Solved by paddy-stone,
Just use rufus to format the drive.. https://rufus.akeo.ie/
Hey, Noob speaking her!
recently i've downloaded Chromium OS to my USB, and i've done some thing not right, so I wanted to install a new, fresh version.
Now I've formatted my USB, cleaned everything, but it's still showing 1,8Gb instead of 16Gb. Can this still return back to 16?
long storry short:
Less Gb available due to instal Chromium OS, can it get back to normal?
https://linustechtips.com/topic/564199-usb-showing-less-gb/
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/564199-usb-showing-less-gb/#findComment-7418832
Almost sounds like the USB is formatted with some ancient (and I do mean *really* ancient) filesystem. Something like FAT16. Any even remotely new filesystem would be able to show the full 16GB.
i7 3770 | Asus GTX670-DC2-2GD5 | Kingston HyperX Blu 16 GB | Samsung 850 Evo 1TB
Fractal Design Define R4 | Nexus RX-8500 850W | Asus P8Z68-V-PRO/GEN3 | 2 x Asus 24.1" PA248Q
“An expert is a man who has made all the mistakes which can be made, in a narrow field.” – Niels Bohr
https://linustechtips.com/topic/564199-usb-showing-less-gb/#findComment-7418853
When I format it, it said: FAT(standard). I hope that provided extra info?
Edit: It uses FAT32
https://linustechtips.com/topic/564199-usb-showing-less-gb/#findComment-7418877
No problem, the OS just takes up the entire partition. So if you want to still use the USb drive the only option is to delete the partition... rufus is way better than windows formatting, much more functional.. you can also use it to create USB bootable drives, which is what I mainly use it for, glad I could help :)
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/564199-usb-showing-less-gb/#findComment-7418915
