Hi! I'm new to the forums though I've been staling them for well over 2 years now, not new to LinusTechTips either, Linus and the rest are the sole reason I'm into computers as much as I am now c: So a small thank you to them!
But anyway; I'm currently in a long distance relationship with someone from America, I'm UK and he's wanting to spend some money on me and him for a new system, he isn't too involved with the planning or building process, he wants me to spec up and build us both a system that he's going to pay for! I've been given a budget of $2000 (Or around 1300 British Pounds) to spend on each system, only the tower, we have the likes of keyboards, mice, headsets and a screen or two. We both want it to be Razer themed as we both love the company so naturally, the case I chose was the NZXT H440 Designed By Razer edition not only for it's Razer theme but it's beautiful look, cable management system, spacious interior and a new other features. However I'd like feedback from the kind people here on the forums on the systems I've planned. They're both essentially exactly the same so I'll only list a single system. The items in bold are locked and ideally I'd not like to replace it with something else however I'm more than open for feedback! (Links are to the UK based retailer Scan.co.uk )
Case - NZXT H440 Razer Edition - https://goo.gl/EE4mXH
CPU - Intel Core i5 6600K - https://goo.gl/pJDp2e
CPU Cooler - NZXT x61 Kraken - https://goo.gl/H4zju6
Motherboard - MSI Z170 Pro Gaming Carbon Edition - https://goo.gl/BsHNVd
Memory - 16GB Corsair Venegence LPX DDR4 2133MHz - https://goo.gl/5BuqDU
Storage - 1TB Western Digital Blue (Salvaging from my old system)
Storage Solid State - 128GB M.2 SanDisk X400 22x80 (Mainly for the OS and select games) - https://goo.gl/QhTD23
GPU - R9 Fury XFX Water Cooled Edition - https://goo.gl/VHInOg
PSU - 750W EVGA superNOVA Fully Modular - https://goo.gl/xCtmWx
Fans - x2 Corsair SP 140 Green LED (To be mounted on the Rad of the x61) - https://goo.gl/5e80Nw
Fans - x1 Corsair SP 120 Green LED (To be mounted on the Rad of the R9 if it's purchased) - https://goo.gl/BT5XX2
Lighting - NZXT Hue+ - https://goo.gl/wfSEKa
I would like to have VR an option in the future, thank you for reading^^
https://linustechtips.com/topic/564193-planned-system-build/
pretty much a solid build, though support for VR is a tough prediction to make...
also, since you're getting the H440, wouldnt you wanna showcase 2x 2.5inch hard disk on the 2.5inch mount on the psu cover? unless it doesnt have a window
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418728
First off welcome to LTT forums!
I think your build is great but maybe try getting a different GPU but you don't need to :P. A 250 GB SSD would work better, in my opinion 128GB is small for todays standard
Hope this helps :P
CPU: Ryzen 5 5600x 4.9Ghz PBO    SSDs: 250GB 850 Pro           STEAM: KezzaMcFezza
GPU: GTX 1070 Strix                                     250GB 970 Pro           MOBO: MSI MPG B550 Gaming Plus
HDD: 1TB WD Black Drive                             500GB 860 Evo          MOUSE: Logitech G502
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418734
Use PCPartPicker to make your list It will show us the exact parts, like which PSU it is that you have. The SuperNova series is good and bad. But get Noctua fans (LTT edition if you want black ones) and get a Samsung 250gb EVO 2.5 instead for less
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418735
Hello we meet again!
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418737
The Razer one does have a window but I'd much rather have faster speeds over a shown SSD, the Hue + takes up a single 2,5" slot though so that'll be on display.
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418739
You won't notice the difference for the most part. And get a 980ti instead of the Fury. You're spending extra for the watercooling you dont need
AXIOM
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418747
well ive seen the hue+ interfering with dual gpu setup so bare that in mind
also, having one empty slot is hideous imo... i have the n450 (same internal chassis) and i filled both slots, just so i dont see an empty slot xD
こんばんわ~
the fury X comes with watercooling, not the fury
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418754
こんばんわ~
His is a watercooled edition for a third party brand. Like what EVGA has.
AXIOM
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418758
Hope this helps :P
Thank's for the warm welcome :D
I'm leaning toward the R9 due to the integrated water cooling, I'm not a fan of a loud computer since mine is currently trying to remake the sound of a Harrier Jump Jet taking of! (3 Pin header decided to stop working so I have no case fans </3)
I agree that 128GB is small but I;d only be using it for the likes of the main OS and some select games, however I may compromise and get the best of both worlds (But unfortunately with the Motherboard I've selected it seems when the M.2 drive is filled two of the SATA 6GB ports stop working, which is a bummer)
I may see about getting a difference card though :3
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418764
ooo, well yea she should get a 980Ti if the price difference isnt big, since the 980Ti have a higher performance than the fury
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418766
Okay :P
P.S i would suggest a 250 GB drive because they can in some cases be more reliable than 128GB ones but imsure someone will shout at me for saying that xD
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418772
I'm not planning to run a dual card setup anytime soon so that's no issue for me right now :3
If you check the link I posted beside the GPU you'll see it is indeed the Fury and it does have integrated watercooling.
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418774
He :b
The current selected card is 450 pound, the cheapest 980 TI on Scan is 530. It's a pretty big jump in my eyes... It does have a better overall performance but I think I'd only get one if it was on offer.
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418788
He :b
well ok xD guess i shouldnt assume
4 minutes ago, MacaroniKyle said:
The current selected card is 4500 pound, the cheapest 980 TI on Scan is 530. It's a pretty big jump in my eyes... It does have a better overall performance but I think I'd only get one if it was on offer.
well tbh, its near the release of pascal at this point, you might wanna wait it out, because VR should be better supported on the new architecture (seeing how 970 defeats 780 Ti in Steam VR test)
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418831
Here is a build I just made. The 980ti is water cooled so it should be pretty quit.
PCPartPicker part list: http://pcpartpicker.com/p/vPKP23
Price breakdown by merchant: http://pcpartpicker.com/p/vPKP23/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($379.99 @ Newegg)
CPU Cooler: Deepcool CAPTAIN 360 273.4 CFM Fluid Dynamic Bearing Liquid CPU Cooler  ($99.99 @ Newegg)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($153.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($64.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($86.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: EVGA GeForce GTX 980 Ti 6GB HYBRID Video Card  ($719.99 @ Micro Center)
Case: NZXT H440 Designed by Razer™ ATX Mid Tower Case  ($178.47 @ Amazon)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $1846.28
Generated by PCPartPicker 2016-03-12 11:04 EST-0500
My Work in Progress PC http://linustechtips.com/main/topic/522048-xeon-build/ <-- That PC was built but never booted:(
My Work in Progress PC 2.0 https://linustechtips.com/main/topic/540583-xeon-build-20-code-name-xenox (Hopefully this one boots.)
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418841
Yeah, can't blame you :P It isn't the first time to happen and it isn't going to be the last ^^ You do have a point though, my only issue is he want's a system soon so depending on the release date I may not be able to wait. If I must I mat just wait for VR and when I'm ready, get a newer card and give mine either away or to him. One of the two will do!
Edit: Spelling takes effort ;-;
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418847
Total: $1846.28
Thanks helpful but I need UK retailers xD He's paying for the parts via Paypal and when his system is built over here in the UK he's going to pay shipping fees for me to send it to him (Which is going to be a burden and awkward)
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418859
why not just build identical pc in own country, shipping fee easily costs as much as a decent gpu tbh
or you can use a lower end gpu for now and upgrade when pascal comes out (earliest in may, or so rumoured)
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418878
He isn't willing to make a computer despite how simple and easy it is, though with some help and advice I may be able to have it assemble it himself.
My only issue with Pascal is price, I'm afraid it's going to be too expensive to fit with the current system, however with it's release there's more than likely going to be a price drop with the 980 and 980 TI range. Maybe not a lot but it's a drop.
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418884
Here is most of the same parts, but in the UK. Also PC parts seem to be more expensive in the UK than in the US.
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418885
Sorry I forgot to actually put the list in the first one.
PCPartPicker part list: http://uk.pcpartpicker.com/p/JH8RLk
Price breakdown by merchant: http://uk.pcpartpicker.com/p/JH8RLk/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  (£289.96 @ More Computers)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£26.99 @ Novatech)
Motherboard: ASRock Z170 Pro4S ATX LGA1151 Motherboard  (£82.66 @ More Computers)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  (£59.14 @ More Computers)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£64.89 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£41.76 @ Amazon UK)
Video Card: EVGA GeForce GTX 980 Ti 6GB HYBRID Video Card  (£629.99 @ Novatech)
Power Supply: Antec TruePower Classic 750W 80+ Gold Certified ATX Power Supply  (£74.49 @ Dabs)
Total: £1329.02
Generated by PCPartPicker 2016-03-12 16:12 GMT+0000
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418891
Swapping the site to the UK domain show's the price to be relatively the same thankfully, let me go see how much it comes to in scan!
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418894
i believe the price of pascal would be to replace the price of current gen products,
ie, the 1070 will be $350 upon release, like the 970 being $350 when its released, but i could be wrong
https://linustechtips.com/topic/564193-planned-system-build/#findComment-7418897
