Hi,
I'd like to know if I could boost my Wifi router range my making a DIY antenna. I thought about using a coax cable which goes in my attic but is connected to nothing. My router is Asus RT-N12. Would it work and do I need to make a special loop fro having a good signal?
Thanks!
https://linustechtips.com/topic/563715-boost-my-wifi/
3 minutes ago, Felix Bonin said:
Hi,
Thanks!
heard of this method but i nvr tested it out tbh
https://www.youtube.com/watch?v=Dma7BmUtuwA
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/563715-boost-my-wifi/#findComment-7413443
54 minutes ago, Felix Bonin said:
Hi,
Thanks!
Can your devices capable of using 5ghz?
https://linustechtips.com/topic/563715-boost-my-wifi/#findComment-7413636
6 minutes ago, Felix Bonin said:
nope..
Well you'll need to get a 5ghz capable wireless router/AP. I'm sure your devices can use 5ghz..
https://linustechtips.com/topic/563715-boost-my-wifi/#findComment-7413696
my devices can but not my router.
Yes, get a 5ghz capable wireless router. Do you have a budget?
https://linustechtips.com/topic/563715-boost-my-wifi/#findComment-7413707
