I got an email from amazon with a tripod as I was looking for tripods recently(still am)
http://www.amazon.co.uk/gp/product/B00K0P047E?redirect=true&ref_=pe_885471_123435491_em_1p_5_ti It is a Manfrotto tripod which is under £50
there was also this Manfrotto: http://www.amazon.co.uk/gp/product/B005KP473Q?colid=16OS7NKMSMSC3&coliid=I1JPPX36X2SHPQ&psc=1&ref_=wl_it_dp_o_pC_nS_ttl
But I have been looking at the Amazon basic tripod which just seems to be bigger http://www.amazon.co.uk/gp/product/B005KP473Q?colid=16OS7NKMSMSC3&coliid=I1JPPX36X2SHPQ&psc=1&ref_=wl_it_dp_o_pC_nS_ttl
are there any differences and which would shall I get?
I will be using this for my tech youtube channel to shoot A/B-ROLL
Hello
https://linustechtips.com/topic/563689-which-tripod-is-better/
buy the cheapest fluid head video tripod head, and fit it to some cheap legs
https://linustechtips.com/topic/563689-which-tripod-is-better/#findComment-7413419
6 minutes ago, TAHIRMIA said:
Good idea..Can you recommend anything
what is your utter MAX budget
https://linustechtips.com/topic/563689-which-tripod-is-better/#findComment-7413450
https://linustechtips.com/topic/563689-which-tripod-is-better/#findComment-7413481
