Extra GPU NEED HELP
Solved by Flowey,
1 minute ago, TheCatWithAPlanYouTube said:so i have two GPUs. one is a GTX 760 phantom and the other is a msi GTX 970. and i was wondering can you SLI the two gpus.
video to my rig setup for more info:
i really want to do something with this GPU then it just sit on my bookshelf . also it the 760 that i have sitting around
YOU COULD try and SLI them, do Nvidia haven't been updating there old drivers as much as they used to, but YOU SHOULDN'T because not a lot of games are compatible with SLI. Also, your gtx 760 willl bottleneck the shit out of your GTX970.
