Hey guys, as promised here are the final pics after the build. I know its prolly not the most impressive setup y'all have seen but this was a big learning curve for me as my very first build. Hope y'all enjoy.
Specs:
Case - Fractal Design Arc Midi R2
Mobo - ASUS Maximus VI Formula
CPU - Intel i7 4770K (Stable overclock of 4.3GHz @ 1.195v)
RAM - Mushkin Blackline 32GB (Rated for 2400Mhz, running @ 2133Mhz)
GPU - EVGA GTX 780 (ACX Cooler)
PSU - Corsair AX860
Cooling - Corsair H100i with two Bitfexix Spectre Pro 120s in a pull, two BF Spectre 140s in the front and one Spectre 140 in the rear as exhaust.
SSD - Samsung 840 EVO 256GB (Two in RAID 0)
HDD - Seagate Barracuda 2TB 7200RPM
ODD - ASUS slim external Blu-ray combo drive
Backup - Seagate External 3TB (USB3)
Keyboard - Corsair K70
Mouse - Razer DeathAdder 2013
Monitor - ASUS PB278Q 27" (2560x1440)
Pics:
I'm gonna go ahead and apologize for shitty photos, my friend was borrowing the good camera so I had to use my iPad to take them. Plus I haven't had a chance to install Photoshop yet so I had to resize them in paint. lol.
Here's the main shot of the innards with the side panel off..
post-34659-0-02475700-1379145785_thumb.j
Here's the ram.
post-34659-0-06672800-1379145788_thumb.j
Here are the ssds and storage drives.
post-34659-0-49562000-1379145789_thumb.j
Here's the GPU.
post-34659-0-56156800-1379145790_thumb.j
Here's kind of a main shot of the insides without the side of the case on.
post-34659-0-72516700-1379145791_thumb.j
Here's with the side panel and the light turned on.
post-34659-0-93213500-1379145792_thumb.j
Finally here's a pic of the various peripherals.
post-34659-0-23888400-1379145794_thumb.j
https://linustechtips.com/topic/56246-first-completed-build/
4.3 at 1.195v?
You must have a great chip or something.
Desktop: Intel i5-3570K (stock) | Asus Sabertooth Z77 | G.Skill RipJaw 16GB 1600MHz | Samsung 840 120GB | EVGA GTX 680 SC+ 2GB | Fractal Design R4 | Windows 8 Pro (soon to have dual boot Mac OS X)
Retina Macbook Pro : Intel i7-3840QM | 16GB 1600 MHz | 256GB SSD | Nvidia GT 650M 1GB | Mac OS X 10.8.5
https://linustechtips.com/topic/56246-first-completed-build/#findComment-759256
Wow, that is quite an overkill system. I like it! Btw that ram looks beastly
Cpu: Intel core i5 4570 gpu: gtx 770 case: cm storm enforcer psu: xfx pro 550w motherboard: asus b85m-g ssd: samsung 120gb hdd: wd caviar blue 1tb ram: kingston hyperx blu 8gb 1600mhz mouse: razer deathadder monitor: some decent samsung 19" keyboard: CM Storm TK Blue
https://linustechtips.com/topic/56246-first-completed-build/#findComment-759257
Why is it overkill
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/56246-first-completed-build/#findComment-759266
Those mushkins look great! I'm curious to know how that Corsair K70 is treating you.
Main Rig: Illya V2, the Tiny Titan: ||i7 8700k 5GHz @ 1.385v (delidded)|| ||NVIDIA RTX 3090 FE|| ||KrakenZ63|| ||ASRock Z390-Phantom-ITX/ac|| ||Corsair SF750||
2nd Rig: Illya V1, the Air Cooled Prodigy: ||i7 4790k 4.4GHz @ 1.3v|| |NVIDIA RTX 2080 FE|| ||Be Quiet! Dark Rock 2|| ||ASRock Z87-E|| ||SeaSonic G-Series 550w (Carbon Fiber Mod)||
Captain isHypnophobic of the LTT Conglomerate.
https://linustechtips.com/topic/56246-first-completed-build/#findComment-759271
4.3 at 1.195v?
I have 1.195 set in the UEFI, but I guess the way AIDA64 works it bumped it up to 1.216 when I did the stress test.
Really? I thought I had like a really mediocre processor. lol.
https://linustechtips.com/topic/56246-first-completed-build/#findComment-759272
It's louder than I expected honestly... It's my first mechanical keyboard. I might try those silencing kits later down the road. Idk. The only reason I got it was because Logan on TekSyndicate recommended it on their review video.
https://linustechtips.com/topic/56246-first-completed-build/#findComment-759274
Thanks bro. Hey, it may be overkill if I was just doing gaming, but baking high poly definition to low poly meshes is a very intensive process and its what I do on a daily basis.
https://linustechtips.com/topic/56246-first-completed-build/#findComment-759279
Oh I see, well hopefully you didn't regret the purchase. But yeah I thought so... those MX Reds are very clicky, I'm actually looking for a keyboard for my build. Would recommend that? Or is it really loud to bear?
https://linustechtips.com/topic/56246-first-completed-build/#findComment-759285
It's alright; I don't regret it. If you bash on the keys you can hear them on the other side of the house, but if ur light on the type, then they can be quite... The spacebar is definitely noticeable though.
https://linustechtips.com/topic/56246-first-completed-build/#findComment-759294
Why is it overkill
32 gigs of 2133 ram..
https://linustechtips.com/topic/56246-first-completed-build/#findComment-759334
So basically it's quiet when you need it to be and as loud and ragey as you when you need to be. I'll consider an MX Red switch keyboard then. Thanks!
https://linustechtips.com/topic/56246-first-completed-build/#findComment-759351
Missed that part, but he has the money and maybe he need the ram?
https://linustechtips.com/topic/56246-first-completed-build/#findComment-759382
He probably bought the ram for how cool it looks, and i don't blame him for that.
https://linustechtips.com/topic/56246-first-completed-build/#findComment-759424
HAHA
https://linustechtips.com/topic/56246-first-completed-build/#findComment-759467
Full slots look better than two empty slots, and it's pretty much the easiest way to "future proof" a system for the foreseeable future.
https://linustechtips.com/topic/56246-first-completed-build/#findComment-760691
baller!
Love the case as well.
nice
nice build man.
Thanks guys! :D
Yea pretty much. lol
https://linustechtips.com/topic/56246-first-completed-build/#findComment-760991
Nice build :)
CASE: FRACTAL DESIGN DEFINE R4  |  MOBO: MSI MPOWER Z77  |  CPU: Intel i5 3570k @ 4.4 GHz  |  CPU COOLER: NOCTUA NH-D15  |  GPU: EVGA GTX 770 SC |
PSU: CORSAIR AX860 W/ RED BRAIDED CABLES | SSD: SAMSUNG 840 EVO 250 GB | HDD: WD BLACK 1 TB | FANS: 3x NOCTUA NF-A14 | MONITOR: HP W2371D
KEYBOARD: CM STORM QFR MX BLUES W/  PBT KEYCAPS  |  MOUSE: LOGITECH G502 | MIC: AUDIO TECHNICA AT2020 | HEADPHONES: SENNHEISER HD 558
https://linustechtips.com/topic/56246-first-completed-build/#findComment-764627
