I was stress testing my cpu today when I noticed that the cpu wasn't using its limit(its limit is 80 watts and it was using 64) even though I have a good 400 watt cooler master power supply. so to rectify this problem I gave the cpu its own 500 watt(external) supply and had the 400 watt supply power everything else inside the case AND SAME THING AGAIN I. don't know what the problem is, also I had thermal throttling turned off and it didn't make a difference and during the test all 4 cores(and 8 threads) were pinned at 100%
-specs-
asrock b85m pro4
intel xeon E-3 1241v3 stock cooler
cooler master rs-430-PCAR
16 gb of geil memory 1600mhz
 320gb western digital blue
Kingston 120 gb ssdnow ssd
2 asus r-rw drives
cmedia sound card
NVidia GeForce 6600 gts(reference design, powered by the 400 watt supply through pcie power)
NVidia GeForce 6600
2 port pci usb card
https://linustechtips.com/topic/562274-cpu-not-running-at-full-power/
its looks like your cpu might be themral throttling; its at 95 degrees.
Edit: im blind, it says right there on the second chart that your cpu is indeed throttling.
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
Just now, Adam7868 said:
but I turned thermal throttling off
you cant turn off thermal throttling. its automatic when your cpu reaches unsafe temps to keep it from blowing itself to kingdom come. The only solution is to get a better cooler/airlfow
if using p95, use the following custom to prevent thermal issues:
p95-1344.png.ee9b5963a43e0f2c67092b6b9e4
in AUTO or adaptive mode, the voltage increase will easily increase thermal loads with no projected performance increase. as noted, you should not use synthetic stress apps when the voltage mode is in adaptive mode only when in manual or static voltage mode.
also verify, the pins of the stock cooler are visible from the back of the motherboard. either the HSF isn't secured properly or that is not a "golden" chip for voltage at 1.11v
Its clearly stated and written on the middle of the graph, ( CPU Thermal Throttling : 12 % ): Overheating Detected so yea thats why its going back to default clocks.
Ryzen 5 3600 | MSI B450 Tomahawk Max | Corsair Vengeance lpx 32gb 3600mhz | EVGA GeForce RTX 3080 FTW3 ULTRA GAMING | XPG Core Reactor 850w
the asrock motherboards allow you to turn it off
wow I guess settings really do make a difference computer is noticablly slower than the aida 64 stability test and the cpu isn't thermal throttling at all despite the cpu temps are in the 90 degree range but still the problem persists
should I try raising voltages in the bios to get full performance
what do you mean by "golden" chip
Even if you could, why the hell would you want a CPU running at 90C+!? Thermal throttling is there for a reason; to protect your CPU.
Errr, no. You most certainly do not want to be cranking up the voltage with your CPU already running at ~90C. It's already way too hot, forget more voltage, you desperately need either less voltage or a better CPU cooler.
I must advise that the cpu cooler I'm using came with the the processor
and also I'm looking into the problem I'm trying to decide between heat pipes or water cooling
The stock Intel cooler is designed for stock speeds and stock voltage, that's it. If you start turning things up, you'll end up with unacceptable temps very quickly.
There are many great options for air and water cooling. Even something cheap like a Hyper 212 will be a decent improvement over the stock Intel cooler. On the other end of the scale, something like a Noctua NH-D15 or a Corsair H110i would be great high end air and AIO options, respectively.
There are many great options for air and water cooling. Even something cheap like a Hyper 212 will be a decent improvement over the stock Intel cooler. On the other end of the scale, something like a Noctua NH-D15 or H110i would be great high end air and AIO options, respectively.
do stores still sell the cooler master nepton 140xl
1 minute ago, MagnusGrønstad said:
http://www.staticice.com.au/cgi-bin/search.cgi?q=Cooler%20Master%20Nepton%20140XL
I think you can find them all over the internet to get them shipped to you.
I had this on my computer originally but took it off and put it inside the server where thermals were a big problem
these cooers were great and I hope to buy another one
No idea, but unless you can't fit a 240mm+ AIO or a big air cooler like the NH-D15 in your case, 120mm and 140mm AIOs don't make much sense; good air cooler will get better temps, be cheaper and be more reliable.
