2 minutes ago, Nafiul said:
Core i7 6700k
Gigabyte h110m s2pv ddr3
6gb ddr3 1333mhz RAM
Transcend 370s 256gb ssd
Toshiba 2tb hdd
Thermal take smart SE 630 bronze semi modular
MSI gtx 970
I build this but will it be enough for 720p gaming at max
yeah for sure. will run 1080p @ max settings 60fps
My rig: r7 1700 @ 3.9/1.35v, 16gb ddr4 3200, assorted rando SSDs, hx 1050, vega 64 1650/1025
MY $75 BUILD https://linustechtips.com/main/topic/576889-the-75-build-log/#comment-7547280
https://linustechtips.com/topic/562140-first-build-complete-d/#findComment-7393473
1 minute ago, Nafiul said:
What a relief
Because I'm genuinely unsure... Can a H110 motherboard overclock?
If yes, you're fine
If no, either get a motherboard that supports overclocking, or get the 6700 (non-K SKU)
Also, if you plan on overclocking (which a K SKU generally indicates), it's highly recommended to get an aftermarket heatsink.
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
https://linustechtips.com/topic/562140-first-build-complete-d/#findComment-7393495
