Hey LTTF,
I know I already had a question like this but I changed up the build a little and ended up saving some money. Can you guys please tell me if all of this will work together and fit. And if I have enough wattage.
CPU: http://www.amazon.com/dp/B0136JOMXC/?tag=pcpapi-20
GPU: http://www.amazon.com/Gigabyte-Gaming-Graphics-GV-R938XG1-GAMING-4GD/dp/B017WMD1VI/ref=sr_1_1?s=pc&ie=UTF8&qid=1457471102&sr=1-1&keywords=r9+380x
MOBO: http://www.amazon.com/Gigabyte-LGA1151-Intel-Motherboard-GA-H110M-/dp/B0165YUDTM/ref=sr_1_1?ie=UTF8&qid=1457474999&sr=8-1&keywords=lga1151+ddr4+motherboard
Power Supply: http://www.amazon.com/dp/B018JYHBE6/?tag=pcpapi-20
Ram: http://www.amazon.com/Kingston-2133MHz-Non-ECC-Desktop-HX421C14FB/dp/B00TY6A56U/ref=sr_1_3?s=pc&ie=UTF8&qid=1457456113&sr=1-3&keywords=ddr4
Storage: http://www.amazon.com/Blue-Desktop-Hard-Disk-Drive/dp/B0088PUEPK/ref=sr_1_1?s=pc&ie=UTF8&qid=1457397024&sr=1-1&keywords=1+tb+hard+drive
The Case: http://www.amazon.com/gp/product/B00RORBQNW/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=1944687602&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B00NGMIBUU&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0AGYYHPPQGVCEG5CBZ10
I know it is a lot but please if someone can do it and actually give me a real response that is correct that would be great also for the power supply I am going with the 600 watt option not the 700 or 500 watt. And will it all fit in the case? I know I sound like a noob but I know what I am doing just that input from people that have been doing it for longer is always useful. I know someone will say just go to pc part picker... but they don't have the parts in this list. So thank you so much if you do it.
https://linustechtips.com/topic/562112-will-this-build-work/
swap that gpu for a sapphire or MSI version. Gigabyte's AMD cards are terrible.
swap that PSU for something like an EVGA G2 model.
everything else works, but add an SSD such as the OCZ trion 150 for faster boot times for sure
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/562112-will-this-build-work/#findComment-7393113
What's your budget and purpose of the PC?
There's no MSI 380X btw.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/562112-will-this-build-work/#findComment-7393137
my bad
then get a sapphire card
https://linustechtips.com/topic/562112-will-this-build-work/#findComment-7393146
Gigabyte don't make bad amd graphics cards and the psu is fine becuase it is bronze certified 80+ and again it is budget I don't have a lot of money to throw at this thing and I don't really care about the boot up time as I don't have the money for the ssd. But thank you for telling me it works.
https://linustechtips.com/topic/562112-will-this-build-work/#findComment-7393206
He's right in the PSU department. Sure, it's Bronze certified. But if you can find something better for cheaper, do it. Also, you barely need a 500W PSU (you don't, actually), let alone a 700W.
EDIT: Gonna pull @STRMfrmXMN and @Aniallation into this to see what they recommend to replace that PSU, I'm almost 100% certain there is a better option out there.
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
https://linustechtips.com/topic/562112-will-this-build-work/#findComment-7393219
Gigabyte AMD cards are notoriously bad compared to their Nvidia cards. 80 PLUS certification does not deem a quality PSU and that EVGA is not a great quality unit and I'd skip it if going to go for a 380X. An EVGA GQ 650W already has enough wattage for two of those cards and is much better as is a Seasonic M12 if those fit in your budget.
https://linustechtips.com/topic/562112-will-this-build-work/#findComment-7393351
Thanks man
https://linustechtips.com/topic/562112-will-this-build-work/#findComment-7393388
Thank you
https://linustechtips.com/topic/562112-will-this-build-work/#findComment-7393391
Do you know what gpu I should get I want to get a r9 380 x but what company?
380X is good but I'd recommend Sapphire or MSI before Gigabyte. XFX is decent as well.
https://linustechtips.com/topic/562112-will-this-build-work/#findComment-7393426
53 minutes ago, MIXFUSED said:
Yup!
https://linustechtips.com/topic/562112-will-this-build-work/#findComment-7396889
