Power Supply HELP!
Go to solution Solved by STRMfrmXMN,
13 minutes ago, GrimPod said:
Im sort of on the same boat as you nullbot but ive heard bad things about the RM series
And if i can i would want a fully modular one
The RM series is OK, just not for the money. The RMx and RMi are a completely different unit than the RM so they're fine.
30 minutes ago, GrimPod said:
So i had asked on here about a pc build im doing and which power supply to go with, and i was recommended 750W,
Ive since then changed the build a little bit and was curious and i tested PSU calculators and it recommended a 550W
So just gonna show the new build and just get opinions.
Case: Corsair Graphite 780T White Full Tower Case
Motherboard:  ASUS Z170-AR Motherboard
CPU:  Intel Core i7 6700K
CPU Cooling: Cryorig C7 Compact CPU Cooler
RAM:  Corsair Vengeance LPX CMK16GX4M2A2400C14 16GB (2x8GB) DDR4 Black
GPU:  ASUS GeForce GTX 970 Turbo 4GB
Storage: Samsung 850 EVO Series 250GB 2.5in SSD
Storage: Seagate Barracuda 2TB ST2000DM001
Optical drive: LG BH16NS40 16X BD-R Blu-ray Writer OEM
Mouse/Keyboard:  CoolerMaster CM Storm Octane Gaming Bundle
That system will rarely, if ever, go over 300W so take that as you will.
The EVGA 650W GQ is often found for under 70 USD so go for that or the EVGA GS/G2/B2
https://linustechtips.com/topic/562107-power-supply-help/
Yes it should be fine and also good choice of PSU.
Magical Pineapples
https://linustechtips.com/topic/562107-power-supply-help/#findComment-7393076
https://linustechtips.com/topic/562107-power-supply-help/#findComment-7393209
