Scythe mugen max vs Hyper 212 evo
DiscoBanana
Hey guys,
is the mugen max better that hyper 212 evo, and is it worth the extra 13 € ?
what cpu are you using?
The hyper does a really good job with my i5 4460
I didn't know what to put here...
The Mugen max is a 140mm fan CPU cooler, I have the Kotetsu, which is 120mm, and performs like a champ.Also the mounting system is really simple and effective. Get the Mugen, it is really worth it
Yes, it's better. Easily worth an extra 13€. But it can be a pain in the ass to mount if you don't happen to have just the right screwdriver. Long story short, mount it and the RAM with the motherboard out of the case. Then mount the mobo in the case with the case laying on it's side. You'll know why, if you don't. :P
