Fan splitter help
sidskofa
If I use a fan splitter to power 2 fans from one 3pin fan port will both the fans only run %50 as fast as normal?
Thanks Sid :D
They should be controlled by the motherboard if they are plugged in that way by the spilter.
Main Gaming and Streaming PC: http://pcpartpicker.com/user/Vinsinity/saved/TjwVnQ
Ultrabook and College Laptop:
XPS 13 9350:
i5-6200U
8GB RAM
Samsung PM951 250GB M.2 Solid State Drive
Workstation Laptop:
Sager NP8672 (P670SG):
i7-4720HQ
32GB (4 x 8GB) CORSAIR Vengeance Performance
Samsung 850 EVO 250GB M.2 Solid State Drive (Boot Drive)
Samsung 950 PRO 512GB M.2 Solid State Drive (Video Drive)
Crucial MX100 250GB 2.5" Solid State Drive (Secondary SDD Storage)
Western Digital (Blue or Black) 1TB 2.5" 7200RPM Internal Hard Drive (Storage Drive)
GeForce GTX 980M 4G
no they will both run at full speed and draw twice as much current
Ahh ok thanks :)
Thanks Sid :D
Depends on the Splitter. Many Splitters have 1x5v and 1x7v. If that´s the case, not both can run with 100%.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
? I would say thats very rare case. Fan header cables are PWR-GND-RPM(-PWM). Your splitter sounds like molex connector with only certain cables connected.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
