SP120 PWM Performance or Quiet for GTX980ti Hybrid radiator and Corsair H60 radiator
Solved by W-L,
8 minutes ago, RGT said:Hi,
I will buy a Corsair H60 and a GTX980ti Hybrid.
I want to replace the stock fans, but i don't know which is better to buy, they are at the same price on Amazon.
SP120 PWM Performance or Quiet???
I like silence, but i think that i can adjust the speed in the BIOS to have better temps until i see that the noise is good, right?.
or better Quiet edition?.
I woudl recommend the Quiet editions the performance ones are still audible even turned basically all the way down
