Liquid temperature same as CPU core temps under max load?
Solved by Beeeyeee,
7 minutes ago, tatelee69 said:Hi there,
I'm kinda confused I'm running a stress test with Aida right now with my kraken at full speed and I'm looking at my cam software and it says my liquid temp is 36C and then my current CPU temp is 24C and 35C on each socket.
Do I need to reapply thermal paste or is my kraken working properly? I just never thought your liquid was suppose to be warmer than you CPU or the same temp as your sockets...
no thats totally normal dude. your liquid can keep your CPU cooler than it is haha. but its okay dude I keep my fans on 50 max and under total full load its fine.
