I am following the book Unity in action and have run into an issue with some of the code. I am unsure if the author tested the code as I have the following issue:
 1. With the scripts added separately all functions work it's only when they are added together that there is an issue.
 2. When I look up my character automatically moves forward
 3. When I look down my character automatically moves backwards
**EDIT: If gravity is set to zero I do not move forward or back, but I do float**
**My Mouselook script:**
public class Mouselook : MonoBehaviour {
    public enum RotationAxes
        MouseXandY = 0,
        MouseX = 1,
        MouseY = 2
    public RotationAxes axes = RotationAxes.MouseXandY;
    // Use this for initialization
    void Start () {
    public float sensitivityHor = 9.0f;
    public float sensitivityVert = 9.0f;
    public float minimumVert = -45.0f;
    public float maximumVert = 45.0f;
    private float _rotationX = 0;
    // Update is called once per frame
    void Update () {
        if(axes==RotationAxes.MouseX)
            transform.Rotate(0, Input.GetAxis("Mouse X") * sensitivityHor, 0);
        else if(axes==RotationAxes.MouseY)
            _rotationX -= Input.GetAxis("Mouse Y") * sensitivityVert;
            _rotationX = Mathf.Clamp(_rotationX, minimumVert, maximumVert);
            float rotationY = transform.localEulerAngles.y;
            transform.localEulerAngles = new Vector3(_rotationX, rotationY, 0);
        else
            float delta = Input.GetAxis("Mouse X") * sensitivityHor;
            float rotationY = transform.localEulerAngles.y + delta;
**My FPSInput script:**
public class FPSInput : MonoBehaviour {
    public float speed = 3.0f;
    public float gravity = -3f;
    private CharacterController _charController;
    void Start () {
        _charController = GetComponent<CharacterController>();
    void Update () {
        float deltaX = Input.GetAxis("Horizontal") * speed;
        float deltaZ = Input.GetAxis("Vertical") * speed;
        Vector3 movement = new Vector3(deltaX, 0, deltaZ);
        movement = Vector3.ClampMagnitude(movement, speed);
        movement.y = gravity;
        movement *= Time.deltaTime;
        movement = transform.TransformDirection(movement);
        _charController.Move(movement);
https://linustechtips.com/topic/560601-unity-issue-mouse-look-and-movement/
