4k hdtv as pc monitor
papapoi
hi everyone, i would some info on your experiences with pc use on a 4k tv, im currently using a 42' 1080p tv with no problems, my eyes and reaction time is pretty bad so i dont play much shooters, unless you count fallout 4 as one.
just wondering since i just picked up one from walmart for $360 , if its not good my parents need a new tv anyway,anyone out there with good or bad experiences with 4k tv's for pc use? thanks for any replies
if i post a link to amazon try to use the LTT affiliate code to help the channel http://www.amazon.com/?_encoding=UTF8&camp=1789&creative=390957&linkCode=ur2&tag=linustechtips-20
The experience wont be affected by the screens resolution, but instead the screens input lag and pixel response.
TV's generaly have higher input lag figures and, in the case of LCD's, slower pixel response making them less ideal as PC VDU's.
Every TV will be different however, so the only way to know in advance is if there is a review out with a full array of tests, like on TFTCentral, where input lag, pixel response, colour accuracy etc are fully tested.
I personally use a 42" Plasma 1080p screen. BUT this screen is not a smart TV, and has minimal image processing so the input lag is low, and as its plasma Pixel response is instant.
You can get rather large monitors nowadays, so if u have the option, always get a monitor. That being said there are exceptions. Philips 4k 40" VA monitor is basically a cut down TV and unfortunately does have rather high input lag compared to 'proper' monitors. That being said its still within acceptable parameters for gaming, just maybe not for professional/ high end FPS gamers.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
