Can you atleast connect to the internet?
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
Connect to the internet, go to website, download drivers, install drivers.
If you can't access on that PC, do you have another you can use? If so, download the drivers and transfer them over to said PC and install.
2 minutes ago, Comic_Sans_MS said:
Download the drivers off the ASRock website, if generic drivers are not working steal an optical drive from an old computer.
I got a laptop i tried to find but theres lots of download choices. Do i download the boot driver?
Which operating system do you have installed?
Also, there is no such thing as "boot driver", for as far as I know.
20 minutes ago, Dewam said:
http://www.asrock.com/mb/Intel/H97M/?cat=Download&os=Win1064
If you have windows 10 64 bit, just click the link and download the things you need.
just download all of them except the vga, im assuming you have a video card which you can get once your ethernet is working and put them on a flash drive and install them on your new pc
if i post a link to amazon try to use the LTT affiliate code to help the channel http://www.amazon.com/?_encoding=UTF8&camp=1789&creative=390957&linkCode=ur2&tag=linustechtips-20
2 hours ago, gonfalons said:
LPT for later, install your motherboards ethernet drivers on a USB stick for your current and upcoming builds because it can be a real hassle trying to get connected sometimes.
I havent install any os yet
Please, DO install an OS. After that, depending on which OS you installed, you can ask about drivers.
Most of the newer operating systems out there will automatically download and install drivers for pretty much everything you need. So you won't need to do it manually.
The only requirement for that to happen, is to have a working internet connection. If your internet connection is not automatically detected, you might need indeed the LAN/Ethernet driver. You can download that from a different machine and then transfer it and install it on this one.
So do that first. If you need specific drivers or you're not satisfied with the ones already downloaded by your operating system (again, this does not apply to all operating systems and hardware configurations, but it does apply to most and especially to the newer ones), you can go here and download what you need, depending on your operating system.
