1 minute ago, El Bombo said:
I want to use it as additional space aside 128GB SSD with Windows and 300GB HDD
THIS WILL DELETE ANYTHING ON THE DRIVE YOU ARE FORMATTING!!!!
Boot into your SSD like normal
Right click on the drive in explorer and click on format. Then Format the drive
format.png.7977fab484ad0820f298f268f7814
https://linustechtips.com/topic/560444-need-help/#findComment-7375318
