Cheapest CPU for R9 280x
Go to solution Solved by crystal6tak,
52 minutes ago, Sikator said:
I edited the post, Buying second hand parts was what i thought of. But looking around i just wanted to know exactly what is my best option.
Ebay isn't too much of an option as if i buy for more than 30$ i will have to pay prob 10-15$ in taxes.
There is a lot of local stuff, people selling 10-20 CPU's etc but they are way out of my league of knowledge as most dual cores and generally older CPU's Especially AMD isn't my field.
My goal is to find how low i can go with still maintaining the GPU's performance.
Right I see...well, if it helps, I'll use codenames for reference then. I haven't actually tried buying any second hand parts before so I don't know what's the most popular, sorry!
At the intel side:
Nehalem 4 or more cores (i7/i5 900/800 series) at 3 Ghz or higher is good.
Sandy bridge/Ivy bridge/Haswell/Skylake 2 or more core (i3/i5/i7 2000/3000/4000/6000 series) at 3Ghz or higher is good.
Honorable mention is the Q6600, I believe this one is quite popular in the second hand market. Pair it with an overclocking board and it'll be a decent chip. Not good, just decent.
At the AMD side:
Phenom x4 900 series (4 cores, higher named x6) at 3 Ghz or higher is decent.
FX chips, 4 or more core at 3 Ghz or higher is decent.
Athlon x4 700/800 series is decent.
Hope this helps!
About 4 months ago a lightning strike hit the outside wall, taking modem, CPU, motherboard, gpu and 2 monitors with it.
I've bought a new pc since then but i just tested the R9 280x that was taken in the strike. and it worked... i had some problems at first.
first try it went straight to bios.
second time nothing.
third time it was stable after resetting the bios, temps and everything is all good running 34c at idle in a 24c room.
So i figured that i would want to see if i could invest in a quick LAN PC for friends if they were over but at first i don't have the cash for an i5 or generally any new stuff. So i am currently trying to find the cheapest CPU that can get at least 80-90% out of the GPU. This is what i need help with.
Budget? I guess for motherboard, ram and CPU max 60-70$ (60€) ish.
I also have 8GB of DDR3 RAM.
Would be nice with at least 1 Sata 6Gb/s
I just want to see and feel how much i can get for as little as possible :)
EDIT: I forgot but buying second hand is the plan! Sorry for forgetting that.
https://linustechtips.com/topic/559971-cheapest-cpu-for-r9-280x/
You probably wouldn't be able to get everything out of your GPU at those prices...
Here's what I came up with, though it's quite a bit above your budget.
http://uk.pcpartpicker.com/p/QtPByc
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/559971-cheapest-cpu-for-r9-280x/#findComment-7370243
6 hours ago, crystal6tak said:
You should look into getting second hand stuff then... Try looking around ebay? You'll find plenty of sellers there shipping worldwide.
https://linustechtips.com/topic/559971-cheapest-cpu-for-r9-280x/#findComment-7372555
At the intel side:
At the AMD side:
Hope this helps!
https://linustechtips.com/topic/559971-cheapest-cpu-for-r9-280x/#findComment-7372930
At the intel side:
At the AMD side:
Hope this helps!
Waow thanks! I love this!
I managed to find 3x i7-920 cpus ranging from 30-45$ each. Tho i realised why i didn't even try these in the first place. Motherboards. impossible to find.
Ill keep searching and see if i find some matches! :)
https://linustechtips.com/topic/559971-cheapest-cpu-for-r9-280x/#findComment-7377293
Welcome!
I did forgot to mention a few more things lol. Firstly pentiums. Just remembered intel has some newer pentiums. Those are dual core chips without hyperthreading. Sandy bridge/ivy bridge/haswell/skylake pentiums are all decent at 3ghz or higher like before. Not good cause they don't have hyperthreading, just decent.
Then there are the xeons, with an entirely different set of names. Refer to wiki I guess lol. But just like before, nehalem, sandy bridge etc etc to skylake are all options. Xeons aren't some special magical CPU's, a quad core sandy bridge i7 is the same as a quad core sandy bridge xeon (Even the socket for the motherboard is the very likely the same!). Only difference being the xeon is locked, more efficient, more stable and supports ECC memory. So yea, you might get lucky and snag a xeon, who knows :P The only issue with xeons are that some consumer motherboards need BIOS updates to recognize the xeon chips...
https://linustechtips.com/topic/559971-cheapest-cpu-for-r9-280x/#findComment-7377643
