So I'm completly new to skyrim modding, something I've always wanted to do, and I'm now ready. I've read that Skyrim should not be installed in your programs folder, and I think mine is. the trajectory is this :
C:\Program Files (x86)\Steam\steamapps\common\Skyrim
So I guess I must install it somewhere else, right?
https://linustechtips.com/topic/559629-skyrim-modding/
You don't have to install it elsewhere, you can just give nmm (would highly reccomend using mod organizer though) access to your program files.
There are many tutorials on this subject
Lets trade CS:GO skins :3
Trade URL: https://steamcommunity.com/tradeoffer/new/?partner=306665646&token=F2tGPmbi
AVID CS:GO PLAYER AND TRADER, FALLOUT AND SKYRIM MODDER
https://linustechtips.com/topic/559629-skyrim-modding/#findComment-7366072
Install Nexus Mod Manager, and go check out Gopher's YouTube channel. He has, by far, the most informative videos on modding, patching, and ENBs. Use Nexus Mod Manager, follow his instructions, and try and stay within the limits of what your PC can do, and you're going to have a wonderful time.
I'd be happy to recommend mods to you based on your specs, if you'd like.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/559629-skyrim-modding/#findComment-7366099
- this is recommended because some mods do not work when installed there or something. Go to Steam > Settings > Downloads and add another install folder (I have just made a folder "Skyrim" in my C: drive). You will have to redownload+install the game, but in the end it will likely be worth it.
- be sure to use a mod manager such as mod organizer or nexus mod manager (I would recommend Mod Organizer since I use it myself)
https://linustechtips.com/topic/559629-skyrim-modding/#findComment-7366120
It's like building a pc all over again, I'm so pumped! Unfortunatly I'll have to refuse your offer do, I want, no, I need to choose mods myself. For my sanity. And tits mods.
https://linustechtips.com/topic/559629-skyrim-modding/#findComment-7366191
NMM is fine,  but I'd recommend Mod Organiser once you catch your bearings and learn how to mod better.
I can't recommend the S.T.E.P. Guide enough for people new to modding.  It'll tech you the basics and get you a good and efficient base to work off of.
Oh, and LOOT (updated version of BOSS, so you know what they're talking about if an old mod you download mentions it)  is an absolute must no matter how experienced a modder you are,  but make sure you read the compatibility guides for every mod you install to make sure all the mods you have are compatible, and to audit any small mistakes LOOT might make
Intel i7 6700k @ 4.8ghz, NZXT Kraken X61, ASUS Z170 Maximus VIII Hero, (2x8GB) Kingston DDR4 2400, 2x Sapphire Nitro Fury OC+, Thermaltake 1050W
All in a Semi Truck!:
http://linustechtips.com/main/topic/519811-semi-truck-gaming-pc/#entry6905347
https://linustechtips.com/topic/559629-skyrim-modding/#findComment-7366200
tits mods = best mods!!!
/s
https://linustechtips.com/topic/559629-skyrim-modding/#findComment-7366249
/s
Oh, you mean the 'advanced physics extensions'.
https://linustechtips.com/topic/559629-skyrim-modding/#findComment-7366872
I use:
-Nexus Mod Manager
-SKSE
-LOOT
-TES5Edit
I have ~100  Mods active atm.
Alot of Graphic Mods that change almost everything from Gras, to Textures, Weather, Water and Lightning. New Spellsystem and Finisher Mod, Armor and Weapon Mods as well as sexy female Bodies/(Faces and new Physics for some Bodyparts) ;) Some Moderators dont like sexy Skyrim Boobs here, so i only can post a censored Picture, sorry.
All the Mods can be found on Nexus. I choose my Mods to keep the feeling of Skyrim original.
If you wanna try it, here is my List. All Mods work together, tested in many hours.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/559629-skyrim-modding/#findComment-7367063
Just started watching it and oh god when he said he'll go into full details I didn't think he'd go so deep, like my mom would be able to mod my Skyrim now hehehe
https://linustechtips.com/topic/559629-skyrim-modding/#findComment-7407219
