Hi Guys,
please help what is the best way of cleaning off the thermal paste on the CPU i know you can use 90% isoprophyl alcohol on cleaning it can you tell me any alternative ways on cleaning it since that alcohol is hard to come by in my place.
thanks in advance
https://linustechtips.com/topic/559577-need-tips-for-cpu-maintenance/
9 minutes ago, yaha1234 said:
Hi Guys,
thanks in advance
You can clean it with just q-tips or just a microfiber cloth, you can wet them with water but not to the point where it will spread moisture to anywhere but the top of the PSU casing.  You really just don't want anything to really get wet.  That's why I would recommend q-tips as they cant really hold a lot of liquid, but a lightly dampened microfiber cloth or even a little piece of paper towel will do.
Rubbing Alcohol / Isopropyl just makes the thermal material come right off, making the process much easier and faster.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
A lot of things work , alcohol ( of course ), TIM cleaner , contact cleaner , you can just use cloth , . Just be sure NOT to use water.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
A coffee filter and yeah any kind of rubbing alcohol... 70% is perfectly fine. 91% and 70% are usually available at any grocery store or pharmacy.
