Power supply shorted out
Go to solution Solved by JeffreyEagan,
No. Most modern power supplies have short-circuit protection. As in, as soon as it detects a short, it flips a switch and shuts itself off. Much like an auto-resetting circuit breaker or a GFCI outlet.
Hi,
Today I was trying out some cheap chinese led strips. I connected them to a molex connector on my psu, but I wasn't careful enough and the positive and the negative wires touched each other. The cables were sparkling and my computer shut itself down. After a couple minutes I turned it back on, and there wasn't any problem what so ever. Should I be worried?
Thank you!
Marci
P.S.: Sorry for my bad english.... :)
https://linustechtips.com/topic/559024-power-supply-shorted-out/
https://linustechtips.com/topic/559024-power-supply-shorted-out/#findComment-7355578
