7 hours ago, smolkomartin1 said:
Mobo: Asus Z170-A
PSU: EVGA SuperNOVA NEX 750W
Nice, I'm using the same combo. Yeah 4.7 should be just fine. If it doesn't work then you can either add more voltage (will result in much higher temps) or lower the oc but the 4.7 oc should work.
https://linustechtips.com/topic/558989-6700k-oc-help/#findComment-7358364
What voltage did you get the 4.7 on? The 1.325 he wants? What was your validation process? I just got mine stable at 4.7 at 1.36v. The 1.35v I had failed after 3 hours of testing but it didnt BSOD. Im currently 8 hours in on my 1.36v. I really want to know because I still have time to return mine and try a different sample.
https://linustechtips.com/topic/558989-6700k-oc-help/#findComment-7358651
 He increased the base clock from 100 to 200 and turned the CPU multiplier to 23 for a 4.6 oc at 1.325v. Sorry, I wasn't paying attention.
https://linustechtips.com/topic/558989-6700k-oc-help/#findComment-7367023
