I have a Corsair CX500.
I want to know how much power im using,
Is there anything that can tell me how much out of the PSU im using?
                                                       Thanks!
https://linustechtips.com/topic/55896-power/
You will need a power meter. Something you plug your computer into and see how much it's using
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/55896-power/#findComment-753808
You can estimate it pretty well.  Take the TDP of your CPU and GPU, add them together, add a few more watts for drives and stuff, and you have a decent approximation of your load power usage.
If you have a normal single GPU setup chances are you're using maybe 400W at load.
Intel Core i7-7700K | EVGA GeForce GTX 1080 FTW | ASUS ROG Strix Z270G Gaming | 32GB G-Skill TridentZ RGB DDR4-3200 | Corsair AX860i
Cooler Master MasterCase Pro 3 Samsung 950 Pro 256GB | Samsung 850 Evo 1TB | EKWB Custom Loop | Noctua NF-F12(x4)/NF-A14 LTT Special Edition
Dell S2716DGR | Corsair K95 RGB Platinum (Cherry MX Brown) | Logitech G502 Proteus Spectrum | FiiO E17 DAC/Amp | Beyerdynamic DT990 Pro
https://linustechtips.com/topic/55896-power/#findComment-753810
Processor (AMD FX-8350 CPU (8x 4.00GHz/8MB L2 Cache)))
 Motherboard (Gigabyte GA-970A-D3P -- FREE Upgrade to ASUS M5A97 R2.0))
Memory (8 GB [4 GB X2] DDR3-1600 Memory Module
 Radeon HD 7870 2GB - Single Card
Case Lighting (Cold Cathode Neon Light - Blue
  Processor Cooling (Liquid CPU Cooling System [AMD] - Standard 120mm Fan))
 Primary Hard Drive (1 TB HARD DRIVE -- 32M Cache, 7200 RPM, 6.0Gb/s - Single Drive))
  Optical Drive (24x Dual Format/Double Layer DVD±R/±RW + CD-R/RW Drive - Black))
All that plus about 5 Chassis 120mm fans.
What do you think?
https://linustechtips.com/topic/55896-power/#findComment-753885
What do you think?
You need a meter. An estimation is not accurate.
For some idea though, the 8350 uses 85 watts at idle and the 7870 uses 12 watts.
https://linustechtips.com/topic/55896-power/#findComment-753919
