Keyboard and mouse causing noise interference though headset
I have a Corsair Strafe RGB and a Corsair Sabre RGB lazer, with the lights on my keyboard are on i get this high pitched noise through my headset (TurtleBeach X12) and when im not moving my mouse a different high pitched noise happens,
when i have the lights turned off on my keyboard and my mouse is moving i dont have that problem, but I'd rather my lights on of course.
Summing up, anyone have any idea why this is happening or know of a way to get rid of it?
8 minutes ago, KxngMikk said:
Yeah
probably bad 5v vrm from the motherboard/power supply
or poorly designed peripherals that draws a sht ton of current
or by any chance, is your usb for the headphones connected to the keyboard?
-sigh- feeling like I'm being too negative lately
Sounds to me like it has to do with the USB port you're using. If I may guess, your headset is plugged into the front panel I/O? My suggestion would be to try and run the USB of your headset to the back of the PC. That is the only thing I can think of outside of buying a more decent headset.
Moozy, wouldn't be surprised if it was the headset it is pretty old and designed for and xbox 360.
Lukripar, I have it plugged into the rear of the pc, so is my keyboard and mouse.
Thanks for the replys but probably will have to get new headset
