Wireless mouse suggestions
theroflcopta
Go to solution Solved by mrconan,
G700 if your feeling fancy.
Hey getting a laptop soon and was looking into a wireless mouse for it and wondering if you guys have a suggestion you really stand behind. Doesn't need any fancy additions 2 buttons and a scroll wheel is enough for me. but price is also not an issue (I'll pay for quality) also my hand is pretty average sized a naga 2013 fits my hand perfectly and I have have a hybrid grip.
My Rig "Corsair air 540, MSI Z87-G45, i5 4670k, EVGA ACX 780, Gskill sniper 2x8gb 1866 memory, Corsair CX500m modular 80+ bronze, corsiar h100i, toshiba 1.5tb HDD." / Peripherals "Acer H226HQLbid Black 21.5" (Main monitor), Acer S200HLAbd Black 20" (auxiliary), Razer blackwidow ultimate 2013, razer naga 2013, razer goliathus 444x355 speed edition, Sennheiser HD8 DJs"
I think if you're buying a wireless mouse for a laptop, basically any wireless mouse will do....
CPU:
Intel Core i5 2500k - Motherboard: Asus maximus iv gene-z - RAM: 2x Corsair Vengeance Blue 4GB DDR3-1600 CL9 - GPU: ASUS GTX 770 DirectCU II
Case: Coolermaster Centurion 5 II - Storage: Crucial M4 128GB, Seagate barracuda 3TB PSU: XFX 650W XXX Edition Modular PSU - Keyboard: Ducky Shine 2 Pro
Mouse: Razer Deathadder 2013 - Sound: Razer Characias
| 3570k @ 4.5 | swiftech h220 ordered after patent issues | EVGA 660ti SC 3gb | 8gb gskill ripjaws | Asus p8z77-v lx | Corsair Ax 750 | Asus Xonar DS | Corsair C70 white | CM quickfire rapid mx browns | G500 |
yeah was thinking g700 or ouroboros
i mean I still want it to be good xD
I haven't gotten a chance to use the G700, but i am using a g500 and the build quality of logitech is outstanding.....
Logitech M315.
Quite light and loud clicks (like cherry mx blues) --depends on what you like.
I have several of these. You can find them on sale as low as $10.
If you want something that is ergonomic and good for gaming, go with Logitech G700s. If you don't need all that fancy stuff, go with what the others have recommended above.
Aight thanks guys i'll most likely use the G700s.
