PC Cooling for Laptop
i had an idea to modify my laptop to using a PC cooling fan like a cooler master hyper x 212 or ETC.
and my laptop is Asus A43SM.
is there anyone here has been modification a laptop cooling using a PC cooling??
and is that works??  and its make me curious now :D
sorry for my bad english and the dumb idea :D:D
https://linustechtips.com/topic/557222-pc-cooling-for-laptop/
theoretically you COULD ghetto fit a desktop's cooler into a laptop
it also depends on your laptop's internal layout,
but if your processor is facing away from the keyboard (downward), you could cut a hole out and zip tie a AIO cooler onto it for the luls and run the pump and fan at full speed with external 12v adapters (or 9v adapter for lower speeds)
but obviously it will have a giant hole underneath it with a heatsink/pump combo thingy sticking out underneath your laptop :D
but ghetto, amirite?
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/557222-pc-cooling-for-laptop/#findComment-7337208
hmm.. sounds like a bad idea for changing my laptops cooling... :D
i must fine a different idea to not make a giant hole and using a cable ties for hold the heatsink.. :D:D
but thanks to answer :D:D
https://linustechtips.com/topic/557222-pc-cooling-for-laptop/#findComment-7337313
https://linustechtips.com/topic/557222-pc-cooling-for-laptop/#findComment-7337322
6 minutes ago, Moonzy said:
or just go clean it if its been awhile since u last done it
i always clean up my laptop and changing the thermal paste and i use a cooling pad + tornado fan.:D
and if i playing a high end games i always release the onboard keyboard (not release maybe, just open it and hold it using something :D and the keyboard is still works :D) and it's increased the FPS :D:D
so i think why not someone try to modify the laptop cooling system using PC cooler..
https://linustechtips.com/topic/557222-pc-cooling-for-laptop/#findComment-7337389
