microphone Alternatives to Samson Meteor and Meteorite?
1 hour ago, Zonus said:The stuff I read was the "Unable to install driver to USB device" error. On a further Google trip, there was an easy fix that worked for most people.
And since you've had a meteor for 2 years, I doubt it'd be a big problem.
I guess I'll just go with the Meteor. It's quite a good value too, and looks great.
Question: How does the Meteor perform at, say, a 1 meter range?
It still sounds excellent with only moderate sibilance and not much lost bass (actually sounds like increased upper bass - not boomy). However, at a normal speaking volume I have to set the Meteor's volume to 80%, and there will be noise. The noise is low enough that for Skype and gaming use, no one will really notice it unless they listen for it. However, it might not be ideal for YouTube use because audio compression will increase the noise floor even further. For Youtube, you should keep the microphone closer to you.
Try to keep the microphone relatively vertical when it is a meter away from you. Or if you're going to tilt the microphone significantly, make sure it's standing on something absorbent like cloth instead of wood or glass or plastic. At a meter away with a strong horizontal tilt, reflections from hard surfaces will add a boxy sound to your voice.
