If you mean keeping the websites open 24x7 then it would require your computer and your VM to be on 24x7 also otherwise you risk your cookie/cache expiring and logging you out. If you don't mind this then go grab VMware Player or VirtualBox for free (I use VMware Player at home).
-KuJoe
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7333994
i would need 1 cpu core for the vm?
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7334013
Grab VMWare Player and a Windows 7 ISO, and there ya go. I was actually just getting ready to set one of those up. :P
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7334039
VMWare Player
Main Gaming and Streaming PC: http://pcpartpicker.com/user/Vinsinity/saved/TjwVnQ
Ultrabook and College Laptop:
XPS 13 9350:
i5-6200U
8GB RAM
Samsung PM951 250GB M.2 Solid State Drive
Workstation Laptop:
Sager NP8672 (P670SG):
i7-4720HQ
32GB (4 x 8GB) CORSAIR Vengeance Performance
Samsung 850 EVO 250GB M.2 Solid State Drive (Boot Drive)
Samsung 950 PRO 512GB M.2 Solid State Drive (Video Drive)
Crucial MX100 250GB 2.5" Solid State Drive (Secondary SDD Storage)
Western Digital (Blue or Black) 1TB 2.5" 7200RPM Internal Hard Drive (Storage Drive)
GeForce GTX 980M 4G
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7334040
Just now, DominicNikon said:
vmware player for vms or do i need to buy the lime tech software
You only need VMWare Player.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7334074
1 minute ago, DominicNikon said:
is vmware player free? also could i use it on 1hdd or would it overload the sata port
It is free, and it will even work on a flash drive, so long as it's large enough for what you're trying to do (don't though, it's slow).
Good example, I have VMWare Workstation (since I do a lot of VMs and I need some of the more advanced features that you wouldn't necessarily need, for example), and I have a folder on my games drive set aside just for VMs, and I could defrag a couple of them and still be able to play a game.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7334105
would usb 2.0 be too slow and how would it work off a flash drive?
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7334127
It would be far too slow, and what exactly do you mean by "how would it work off a flash drive?"
Just wanna give you the best possible answer so you don't say screw it or somehow mess something up. :P
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7334141
can i use it on my 2nd hdd?
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7334149
Definitely.
Just so you know, the VM won't just claim the whole disk as its own. You set a max size limit (like 40 gigs), and then it basically just makes a file for it, kinda like a Word document.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7334156
Definitely.
it only uses a folder?
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7334166
Yup.
Like, this is what the folder looks like where I keep my VMs.
And this is the actual folder of the VM.
And just as proof that it's a thing, here it is actually running (alongside my Windows 10 VM since I was just working in it).
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7334190
1 minute ago, tmcclelland455 said:
Yup.
give me link for download? also do i need to buy a copy of windows?
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7334195
https://my.vmware.com/en/web/vmware/free#desktop_end_user_computing/vmware_workstation_player/12_0
And while you could buy Windows, I want to say Ubuntu support is pretty well buttoned up in VMWare products.
I would go with Windows 7 (assuming you don't go with Ubuntu), and then either hit me up to activate it (;)) or actually buy it.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7334215
how will i get the windows 7 iso with out buying it and how will you activate it
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7334221
believe this is the torrent file for Windows 7 Home Premium 64-bit (a trusted one, of course). https://drive.google.com/file/d/0Bxu8unle-0U0bUxKeUJBQ1g3cTQ/view
And as for how, I have a program which basically inserts a license key and makes Windows think its genuine. I've used it literally DOZENS of times, and it even allows you to put in custom computer info kinda like in this.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/556923-simple-vm-for-school-use/#findComment-7334252
