How should I put my fans
AlbinoTexan
I have 4 fans but only using 3 right now
3 120mm
1 140mm
And  my cpu fan
i have a intake in the front exhaust in the back and intake on the top (the 140mm blowing air on my cup cooler.
Is that good? Should I use my 4th fan?
"Television brainwashing the youth"
"Politicians won't tell us the truth"
3 120mm
1 140mm
And  my cpu fan
if you do intake on front and bottom, exhaust on back ant top creates good airflow.
hot air rises, and the direction of airflow will cause the air to flow over the Mobo chipsets, as well as helping the GPU intake fans.
the exhaust on back and top also help to cool the CPU cooler,
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
How do I do bottom
Just now, AlbinoTexan said:
How do I do bottom
Do you have spots for your fans on the bottom?
Solitaire.
Only where my psu fan goes. I have 1 spot on the side and  2 in the top front.
What case?
Solitaire.
What case?
Rose will challenger. The front doesn't have fan mounts on top but it will be so easy to Jerry rig a fan up there
Ok, I have the galaxy-01.
Here is my config:
exhaust fan top of back
exhaust fan back of top
intake bottom of front
intake on side panel
its ok to have the front fan down by the drive bays.
Solitaire.
Here is my config:
So should I do this
intake on front
intake on side
exhaust on top
echaust on back
So should I do this
intake on front
intake on side
exhaust on top
echaust on back
Yup
Solitaire.
Yup
My temps in my case are 80 and close to 90 around my cpu.
i took the temps with a gun thing my dad has that tells air temp. That's good or will the fan placement make that cooler
What are the rest of your specs?
Solitaire.
Ah I'm not sure I just know the temps in my case. Not the parts them slef. I'm. It at home right now.
3 120mm
1 140mm
And  my cpu fan
2 intake, 1 exhaust.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
but neutral pressure is better.
Solitaire.
errrr.... positive and neutral doesnt have a big difference.
Old Rig
well he HAS another fan, so he might as well use it.
Solitaire.
adding more noise.... the temperatures wont be affected anyway. just adding unnecessary noise in my opinion.
Old Rig
Well my fans aren't loud. Or well I don't think they are.
what fans are they?
Old Rig
what fans are they?
3 are stock rosewill ones and one is a bitfenix
