Hey guys,
I am currently building myself a computer but when I go to turn the power on, the fans and water pump start, but it won't start posting. I have checked the motherboard and memory which are both confirmed as working. The processor was found to be faulty and was replaced under warranty. I thought that this would be the end of it but when I got home it still wouldn't post. I have tried clearing CMOS, re-seated everything, tried different memory positions and so on, to no success. Is it possible that the power supply is causing this?
My components are:
MSI Z170a Gaming M5 motherboard
Intel i5 6600k
Two 8GB Sticks of Kingston HyperX DDR4 2400
EVGA Supernova G2 750w 8o+ Gold
Corsair 750D Airflow edition
I only got the parts two days ago.
Thank you for any help.
https://linustechtips.com/topic/555112-help-please/
4 minutes ago, sillycar91 said:
Is your new replacement CPU faulty?
Intel i7 6700K | MSI Krait Z170A MSI GTX 980 w/ NZXT Kraken G10/x31 Corsair Vengeance LPX 16GB Samsung 850 EVO 500GB SSD/WD Blue 1TB HDD NZXT H440 | K70 RGB/SteelSeries Rival
https://linustechtips.com/topic/555112-help-please/#findComment-7315992
3 minutes ago, sillycar91 said:
Hey guys,
My components are:
Intel i5 6600k
Are you fans plugged in properly?
https://linustechtips.com/topic/555112-help-please/#findComment-7315993
what would fans have to do with the system posting or not ?
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/555112-help-please/#findComment-7316001
The first system I built I did this same thing.
and I also had the same PSU and it turned out to be one of the fans I some how plugged in improperly.
I also had a pc do this becouse the 8 pin CPU cable was not seated properly. I recommend taking all your cables off and reinstalling them.
https://linustechtips.com/topic/555112-help-please/#findComment-7316019
2 minutes ago, sillycar91 said:
All of the fans are plugged in correctly, and atm I don't have a graphics card (poor student). And what are the odds that I get two faulty cpus in a row?
I have been building PC for over 5 years and have built hundreds and in that time I have had 1 bad CPU.
what cooler are you useing?
https://linustechtips.com/topic/555112-help-please/#findComment-7316026
Ive almost never heard of a CPU being DOA (s**t happens, but it's pretty rare)
If you're able to test the computer out with a different PSU, I'd try that first.
My nest guess would be faulty ram/ram slots.
Honestly, take this step by step. TBH Id probably blame the mobo or ram before I blamed the PSU on this occasion, however PSUs are known to be the biggest problem causers.
https://linustechtips.com/topic/555112-help-please/#findComment-7316079
