Using PS3 controllers with my PC
Go to solution Solved by iamdarkyoshi,
Just now, pipnina said:
Yes. Should I not have by any chance?
It should have been plugged in. Try this version:  https://github.com/nefarius/ScpToolkit/releases/tag/v1.5.5787.40106
If the link doesnt work, this is the one you want:
Go into the device manager and uninstall everything else related to your controller first
Up until now I've been using DS3 tool / Motionjoy (it was called one of those things, or both) but I have to re-install it now due to a fresh windows install. Before I install it again, is there a better alternative? I ask because DS3 was quite... "Temperamental" (It only worked properly half of the time, and only on half of computers).
Thanks!
    ~pip
https://linustechtips.com/topic/555015-using-ps3-controllers-with-my-pc/
Better than both of your suggestions is SCP Server. I have had issues with versions newer than 1.5 or whatever, but the newer versions have working bluetooth support
Better DS3 is a replacement for DS3 tool. Both work with motion joy drivers. Better DS3 is exactly what the name says...better. Under windows 7 I was able to get my DS3 working over blu-tooth without a problem using it. After upgrading to windows 10 it is broken for me but that may be due to the upgrade of the OS more than anything else.
浪速の建てるは静か用に建てました!- Build Log Coming Soon!
Thanks!
    ~pip
You either get an app to mimic a keyboard and mouse or mimic an xbox controller.
Thanks!
    ~pip
Use SCP Server. Makes the PS3 seen as a 360 controller. Works flawlessly .
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
Just gave SCP a go, followed a tutorial and installed the xbox controller drivers, the .net 4.5 & directx but it doesn't recognize the controller in the monitor, I have both the monitor and the driver running. Any idea why it doesn't show up?
Scrreenshot, just in case it helps...
Thanks! It's working now!
