After a quick search I found that there is not an active thread on this topic (if there is one please let me know with a link). I know many people would argue that the performance gains from modding your laptop are not inherently worth it, and fundamentally I agree. However being a poor college student I never have enough cash in the back account at one time to purchase the hardware needed for a desktop (yes I am aware you can get in for very cheap, no I don't even have 300 bucks). So what are the basic concepts and ideas on this subject? What kind of changes are practical? Where can you get used hardware for laptops? What kind of performance gains can one expect? Am I just wasting my time thinking about this? Thanks for your help!
P.S. I have a Toshiba Satellite E45-B4100
Link to Amazon http://www.amazon.com/Toshiba-Satellite-E45-B4100-i5-5200U-Processor/dp/B00U9W5EE6
https://linustechtips.com/topic/554893-modding-laptops/
on most laptops the only thing you can change is ram and storage drives
thats not going to give you any significant performance improvement other than faster loading with an SSD
https://linustechtips.com/topic/554893-modding-laptops/#findComment-7313546
The only thing that will boost any type of performance is an SSD and some RAM. You can't add a GPU. I'd just recommend you save your money for desktop components.
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/554893-modding-laptops/#findComment-7313561
I have a couple old ones where you can change the CPU.
i like linux
https://linustechtips.com/topic/554893-modding-laptops/#findComment-7313564
Yes, however, buying a new CPU would burn through pretty much all his cash.
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/554893-modding-laptops/#findComment-7313571
buying old CPUs is even more expensive than buying new ones, especially laptop CPUs
and since its old then the best thing youre going to get is still some outdated processor that needs to fit the same socket, making it a complete waste of money
https://linustechtips.com/topic/554893-modding-laptops/#findComment-7313597
