I think many, many people have this problem.
'Well I gave it after I got windows 7 64 bit (SP1).
What data to give you? Jack's is well placed, sound card has no problems on Windows XP went perfect.
Drivers installed in place, all are ok (if required ss sites, reply)
Name motherboard: Asus P5L-MX
Sound Card name: C-Media CMI8738 / C3DX
I looked driver for windows 7, but have not really found.
Below right, it appears to me, I got sound, and when I put music grows green thing goes up. But unfortunately no sound from my PC (I tried and headphones).
How can I fix this so annoying?
PS: I used 5 programs to find drivers.
* Member of romania, excuse me for grammatical errors *
https://linustechtips.com/topic/554876-sound-problem-windows-7-x64/
use onboard sound instead, there should be drivers for that
I found this try downloadingit aND if not make sure you have the realtek HD audio driver installed
http://download.cnet.com/CMI8738-C3DX-PCI-Audio-Device/3000-2110_4-163508.html
I have an Anet A8 as my project printer and a i3 MK3 for when I want things to work.
I extrude my own filament and haven't saved a penny yet.
My PC:
CPU: Intel i7 8700k
Motherboard: MSI Z370-A Pro
RAM: G.Skill Ripjaws V (2x8GB) DDR4-3200
GPU: GTX 1070 Founders Edition (OC'd)
Storage: 2x 2TB Seagate 5400RPM, 128GB ADATA SSD
Power Supply: EVGA Supernova 750w  B2
Cooling: Noctua NH-D15. 3 Intake Fans, 2 Outtake
Case: Fractal Design Define R6
i have realtek driver installed.
that driver, is for windows XP
13 minutes ago, toniann said:
but I used all driver programs, and everything is alright with drivers.
nothing missing
If that was the case your sound would be working........
You need the SoundMAX ADI Audio Driver for that motherboard.  Get it here - https://www.asus.com/us/Motherboards/P5LMX/HelpDesk_Download/
Choose Vista 64 bit as your OS (Will work with Win7) and expand the audio section, download the first option.
how exactly do manage to get all drivers installed when you can't find them?
Windows XP drivers don't  work with Windows Vista and later.
At the very least try to find Windows Vista drivers
otherwise resort to using onboard sound or over HDMI/DisplayPort if you have a modern GPU
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
I have installed SoundMAX ADI Audio Driver since I installed the Windows 7.
hmm, I don't understand what you say.. I'm a beginner
Try these:
http://www.cmedia.com.tw/EN/DownloadCenter_Detail2/pserno-31.html
http://www.cmedia.com.tw/EN/DownloadCenter_Detail2/pserno-32.html
Ask an adult for assistance
Just now, toniann said:
Install them on both?
yes
5 minutes ago, toniann said:
I installed and I restarted the computer after installation..
not working
good
1 minute ago, toniann said:
why 'good' ?
not working....
oh, I mean that's terrible
buy a new one?
get a USB soundcard for $5
11 minutes ago, toniann said:
I bought a year ago, it does not work after install Windows 7
uninstall windows 7
