So over the years, I would just buy the cheapest hdd and plug it in. Well 3 of these are externals, which I've de chucked 2 and stuck in my full tower, plus a few other existing drives. Oldest two are WD Black 1TB's which were the largest drive at the time I bought them. Wow, now we're at 5TB.
So I have 2x1TB(WD Black), 2x3TB(WD Green), 1x3TB(seagate) and the 1x4TB external still.
My question is, is there any sort of raid or raid like system that would let me utilize the different sized drives without losing any of the drive space?
Right now I just stick files on each drive, independently, I wish there was a better system. Any tips?
https://linustechtips.com/topic/554397-storage-array-system/
to my knowledge if you combine various sizes in raid you can only use the smallest common volume. But depending on what you need to do their may be a non raid option
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/554397-storage-array-system/#findComment-7308478
