@jol159
If you're going to be gaming @ 1080p, then you are WAY WAY WAY overkill on the GPU
for 1080p gaming, a 970 is plenty.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  (£199.96 @ More Computers)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£26.49 @ Ebuyer)
Motherboard: Asus Z170-DELUXE ATX LGA1151 Motherboard  (£228.36 @ More Computers)
Memory: Corsair Vengeance LPX 16GB (4 x 4GB) DDR4-2133 Memory  (£78.24 @ More Computers)
Storage: Samsung 850 EVO 250GB M.2-2280 Solid State Drive  (£77.90 @ More Computers)
Video Card: EVGA GeForce GTX 970 4GB FTW+ ACX 2.0+ Video Card  (£299.99 @ Amazon UK)
Case: Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case  (£84.99 @ Ebuyer)
Power Supply: Corsair 750W 80+ Platinum Certified Fully-Modular ATX Power Supply  (£118.78 @ Amazon UK)
Monitor: Asus PB238Q 23.0" Monitor  (£181.13 @ Amazon UK)
Total: £1295.84
Generated by PCPartPicker 2016-02-24 20:05 GMT+0000
went with the deluxe mobo for the integrated wifi and dual intel gigabit lan, better power supply, better monitor, IPS height adjust swivel etc..
950 pro ssd is also overkill
and you didn't have a case picked out, so i picked one
1 minute ago, MrBucket101 said:
@jol159
PCPartPicker part list: http://uk.pcpartpicker.com/p/fqQC3C
Price breakdown by merchant: http://uk.pcpartpicker.com/p/fqQC3C/by_merchant/
Total: £1295.84
Generated by PCPartPicker 2016-02-24 20:02 GMT+0000
I have a case already (corsair 100r silent edition) and I was kind of thinking of using the gtx 980 ti for vr development in the future
still overkill, you can do that on the 970. Take the money you save and get other better components.
I've got a 980ti, they're great cards. but you're blowing your load here for no noticeable benefits.
If you want to get a 980ti, then you should get a monitor that is worthy of the gpu. 27" 1440p at least. when gaming at 1080p the card will barely even have to clock up
1 minute ago, jol159 said:
I was also wondering does a storage device eg. ssd come with a sata data cable or do you have to get them separately
the sata cables come with your mobo, but m.2 drives don't need cables
