DDC or D5 Pump for some special loop
Guest
Hello there,
I planned to build a system with 1x Fury X and 3x Fury Nanos.It will be doing calculations constantly,so it needs water cooling.So I thought of two seperate custom loops :
1 - CPU loop . maybe RAM,HDD,etc. later
2 - GPU loop , only the four GPUs
But the thing is I cannot decide if I need a DDC or D5.
For CPU I would cram a D5 in the loop
For GPU I thought of an DDC pump
And yes,I am NOT a professional at water cooling.
And yes,I will be running distilled water with biocide
The Case will be a Fractal Design Arc XL
For every pump,I can allow 150€ as maximum
Good bye
Why do you want 2 loops? Its more efficent to have one large loop, and if you have flow restrictions have an additonal pump to assist.
DDC (8w-18w) or D5 for CPU and
DDC MP35x or D5 for the GPU
tbh, a single loop (D5 or 35x) can run the whole lot.
OK.Thanks for the quick reply!
Looks like a DDC would fit.EK blocks arent so smooth.
