What PSU watt power?
Solved by Moonzy,
Just now, Yoo Song Won said:I have an intel i5 4590... is 350 still enough?
well 350W is BARELY enough like i said, it also depends on how many fans you are using, how many hard disk you are using, etc etc
to save time and worries, just get a 500~600W PSU like what i mentioned earlier
u might save a bit of money now but in the end you might need to change out the PSU to another one while if u bought a better one in the first place you would be saving
if all else fails, a 450W is still better than 350W, that's just too low imo...
