So I currently have this light set in my pc.
Satechi RGB LED Light Strip with Remote Control for Computer ( ST-CLEDLS ) https://www.amazon.com/dp/B00QAX8YPY/ref=cm_sw_r_other_awd_ck2YwbT36XV8N
It's currently powered by a molex cable, but I'd like to do away with the molex cable in my pc to make it a bit neater. I have extra sata power plugs in my build. So I was thinking I could get a sata to molex adapter, should this in theory work or is there some reason a sata wouldn't power this light kit?
https://linustechtips.com/topic/553019-case-lighting-question/
yes a sata to molex adapter will work fine
https://linustechtips.com/topic/553019-case-lighting-question/#findComment-7293044
It will most certainly work, but why remove a molex and replace it with a sata to molex?
I guess if you have a modular PSU and the molex has a bunch of other connectors?
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/553019-case-lighting-question/#findComment-7293061
Yes that will work.
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
https://linustechtips.com/topic/553019-case-lighting-question/#findComment-7293466
